A Few More Weights!
35 replies to this topic
#1 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 15, 2013 - 04:04 PM
I have come upon this group of weights. Not sure how to use them as yet. They are around 6.75" X 14.5" X 1.75" each and 12~ lbs. each. The 2 smaller black ones are 8~lbs & the red one is 12~ lbs. They have holes thru them that will fit a 1" bar. Close to 200 lbs all together.
  • sacsr, boyscout862, twostep and 2 others have said thanks
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted December 15, 2013 - 04:06 PM
Work out weights, Good Stuff. :thumbs:
  • KennyP and JRJ have said thanks
#3 olcowhand ONLINE
  • 41,082 Thanks
  • 31,396 posts
Posted December 15, 2013 - 04:09 PM
For the front of a tractor, you could make an extended bumper with a flat plate with upright round bar or stout pipe.  Just slide on how many you need, eazy peezy.
  • KennyP, twostep and JRJ have said thanks
#4 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 15, 2013 - 04:15 PM
That is good. Trying to figure out how to attach on the back of the FF for help in the snow! Can't go wide as they are wider than the lift arms. All 13 of them stacked are 22" tall and about 165~ lbs.
  • JRJ said thank you
#5 olcowhand ONLINE
  • 41,082 Thanks
  • 31,396 posts
Posted December 15, 2013 - 04:20 PM
You gonna be using a rear blade?  If not, just build an A-frame for the 3 point with the same kind of plate with uprights out past the pins.
  • Texas Deere and Horse and KennyP have said thanks
#6 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted December 15, 2013 - 04:21 PM
You will have no problem figuring out how to set them up on the back of the FF. Will definitely give some needed traction when pushing snow.
Geno
#7 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 15, 2013 - 04:37 PM
Good idea Daniel! I can take the sleeve hitch off this one and use the axle mounts for the bottom. Run something up to hook into the 'center link' hook up. Then build out from there.
#8 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 15, 2013 - 04:46 PM
Kenny, if you can use the 3 point to lift them then that's less work for you. Some sort of a hook that would pick them up and then a pin or 2 to keep them from moving once they are lifted by the hitch. Let the hitch do the lifting. It would make it super easy to add or take off the weight.
#9 Talntedmrgreen ONLINE
  • 3,273 Thanks
  • 2,306 posts
Posted December 15, 2013 - 05:08 PM
Always fairly easy to fab a weight box for front, rear or both, and drop them in, especially when working with a 3 point hitch.
#10 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 15, 2013 - 05:18 PM
The challenge is the FF's have one cylinder for all 3 lift points. Not sure I want that to be lifting this weight along with the blade. The 3-point is on the other tractor right now. I'll get something figured out, but I like all the suggestions thus far.
#11 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,535 posts
Posted December 16, 2013 - 07:48 PM
Can you not lift up the 3pt and lock it out with a pin?
#12 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted December 16, 2013 - 08:06 PM
Those sure would look good bolted to the front end at a plow day, like a big tractor!!
#13 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 16, 2013 - 08:18 PM
What are they made of, Kenny?
#14 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 17, 2013 - 01:11 PM
I haven't seen anything to allow that. Thinking the situation over right now.
Plastic covered cement? i think, Will. They have three 1" holes thru them.
If I can figure a good way to hang them. It would take 7 of these to equal the window weights I have up there right now.
  • Texas Deere and Horse and IamSherwood have said thanks
#15 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,535 posts
Posted December 17, 2013 - 01:57 PM
If the 3pt lifts via a rod that runs to the mid-mount lift cylinder the lift rod should have a slot it in to allow the 3pt to float. If that is the case then you could ways lift the 3pt, pin it (if that is an option) or just chain it up.
