Bolens #1330 42" Snowblower Upgrade
bolens iseki g152 model 1330 hydraulic rotate electric spout
14 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted December 14, 2013 - 09:55 PM
I am beginning research and a parts scrounge for the snowblower on my Bolens/Iseki G152.
I am looking to add hydraulic rotation to the chute, and add an electric actuator for the spout tip. The tractor has two spools of hydraulics available, one is currently being used for the lift on the snowblower. The second spool has two feet of hoses attached to it that are used for the deck lift, so I will need to run hoses to the front, use hard lines, or run totally new hoses from the valve.
My current set up:
I want to use a hydraulic motor for rotation, using just roller chain to connect to the chute. I would have weld on a sprocket tooth ring to the base of the chute.
On the spout deflector, I just plan on using whatever actuator I can find cheap, but mounting a sturdy two way weatherproof switch on the outside of the hydraulic control valve box on the fender.
Any hints on where on the net to shop for hydraulic stuff needed, or alternative ideas on hydraulic chute rotation would be appreciated.
Today's search on local CL turned up a used hydraulic motor that was expensive and turns too fast, and an actuator that is 36" long.
  • JRJ said thank you
#2 MH81 OFFLINE
Posted December 15, 2013 - 08:01 AM
There are its of 36 volt 24"-36" actuators out there from the old big sat dishes. They do run on 12, but are slow.
  • Cat385B and JRJ have said thanks
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted December 15, 2013 - 12:47 PM
Looking through CL, I saw a Steiner snowblower with hydraulic rotate. It's design is something I'm thinking about. I have a small (3" stroke) cylinder that came with the tractor. I wonder how much stroke on the cylinder I would need to get 200° of rotation?
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted December 15, 2013 - 05:18 PM
After trying out a couple different configurations, I think the stroke on the hydraulic cylinder I have laying around is too short. I can only get about 45-60° of rotation each way from centered with what I have.
Still thinking.
#5 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted January 26, 2014 - 04:11 AM
I am considering trying for a hydraulic motor for chute rotation. What rpm should I be shopping for?
#6 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted January 26, 2014 - 07:02 AM
Slow!! I sure hope you have something to slip the motor, cause them slow ones have tons of power and might tear things up if you have a OOPS moment..... A window motor works awesome... Surplus Center had some for cheap $.
  • trowel and Cat385B have said thanks
#7 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted January 26, 2014 - 08:13 AM
Just what i was thinking.
#8 tractorskipper OFFLINE
tractorskipper
  • 584 Thanks
  • 355 posts
Posted February 13, 2014 - 09:45 PM
I used a window motor out of a Chrysler van on my Bolens blower.  It has that same worm gear set up as yours.  The mopar motors are non grounded, using a simple polarity reversal for direction change (2P/DT momentary, center off switch).  Works great & the speed is just about perfect.
Will try to post pics tomorrow.
Skip
  • Cat385B said thank you
#9 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted November 16, 2014 - 07:43 PM
Still thinking, the chute rotating every time I lift up is tiresome.
#10 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted November 17, 2014 - 04:54 AM
What you have to drive the shoot is nice and safe. All you need is a drive for it. Hydraulic will be expensive!! I would go electric ! Also hydraulic motors that turn slow are very powerful and could easily tear that blower shoot up...
I motorized my shoot on my Fabco/ Craftsman blower fitted to my Ford by using a powersteering motor assembly from a chevy cobalt.
The same thing could be done for your Bolens unit with relative ease. The Bolens shoot turns easier i think then mine and could easily use a window motor type drive. Surplus Center has all kinds of options cheap.
#11 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted December 17, 2016 - 10:32 PM
During this morning's snowblowing, the blower ate a large rock. For some reason the sheer pin didn't let go. I now have a bent auger. Probably at least a 1/4" off plumb. Debating now how to fix or replace it.
#12 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted January 03, 2017 - 07:51 PM
Tried building a new auger. Complete and total failure, I cannot get it balanced. Shakes a ton, robs power, too heavy, doesn't throw worth a darn. Back to the drawing board.
  • KennyP and Mark 149 J. have said thanks
#13 shorty ONLINE
shorty
  • 5,776 Thanks
  • 5,391 posts
Posted January 03, 2017 - 09:46 PM
That's a serious bump in life's road. Are you fixing the old or starting completely new?
#14 Cat385B ONLINE
    HAZMAT CAT
  • 14,286 Thanks
  • 10,116 posts
Posted January 03, 2017 - 10:39 PM
The old auger is almost an inch out of true. The one pictured above was good until I started welding on the paddles. Got it running smooth when I added the outer most paddles, then something went askew after that.
I'm looking at other options. Plow, pusher, rear snowblower, something you'll see in another thread, and moving to Florida.
I am currently using the broom. But a large snowfall when I'm not home is going to be an issue.
Edited by Cat385B, January 03, 2017 - 10:44 PM.
#15 ClassicBolens OFFLINE
ClassicBolens
  • 1,388 Thanks
  • 496 posts
Posted January 08, 2017 - 12:57 PM
I would find a donor 42" single stage blower auger from a Large Frame, Q Series or later 5000 Series, DuraTrac or Troybilt GTX. Your 1330 should use auger part # 1721278 which is same as most of the Large Frame and Q Series. I'm most certain any of the others could be used as well, however I believe the large sprocket is different.
Here are the auger part numbers and the corresponding blower models.
1718738 - 18042
1721278 - 18044, 18100, 18103, 19240 - this part # supersedes to 1751097
1750860001 - 50142, 14062, 17377
1757932 is an alias part # to 1750860001 but no listing as to which models it fits.
Hope this helps.
Edited by ClassicBolens, January 08, 2017 - 12:58 PM.
  • Bolens 1000, Cat385B, WrenchinOnIt and 1 other said thanks
Also tagged with one or more of these keywords: bolens, iseki, g152, model 1330, hydraulic rotate, electric spout
