Why Is It So Hard To Find ...
waterloo rims
12 replies to this topic
  • 2,325 Thanks
  • 1,496 posts
Posted December 13, 2013 - 04:20 PM
... a set of rims that will fit my Waterloo walk behind?  They are 5 on 4.5" bolt pattern with a 3" center hole and need to accept a 6-12 ag tire.  Seems simple, but I don't know where to go.  I've been to the JD parts department, Good Year, etc.  Anyone with any ideas?
  • Texas Deere and Horse and JRJ have said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted December 13, 2013 - 04:35 PM
Have you checked with Miller tire. They might have a lead on where to get them.
  • New.Canadian.DB.Owner and JRJ have said thanks
#3 Alc OFFLINE
  • 6,741 Thanks
  • 7,395 posts
Posted December 13, 2013 - 06:41 PM
Though these don't look original they would get the job done
http://www.sigmatire...logs/wheels.pdf
#4 wilberj ONLINE
wilberj
  • 4,988 Thanks
  • 5,588 posts
Posted December 13, 2013 - 07:01 PM
http://www.ebay.com/...cat=0&_from=R40
I see you looking for rims not tires now opps. :D
Edited by wilberj, December 13, 2013 - 07:53 PM.
#5 nbent ONLINE
nbent
    customizer
  • 652 Thanks
  • 532 posts
Posted December 13, 2013 - 07:18 PM
i have some rims like that but i will need to measure the pattern
#6 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted December 13, 2013 - 07:44 PM
The three inch center is large. I bet that measurement is the difficult one to find.
I don't know of anything but good luck.
#7 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted December 14, 2013 - 01:10 AM
Those look like the common rim for GTs. Just checking, but are you sure its 4.5" and not 4.25"? All the rims I have laying around are 4.25" with a 3" center. The hubs look close to the same as a simplicity. That's the only reason I'm questioning the bolt pattern.
#8 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted December 14, 2013 - 03:26 PM
Hard to tell from the picture but can the rim be repaired ? Miller in the USA and Huron Tire in Ontario can get most anything what I did was put a blank rim on the Empire hub another friend with a Planet Jr. removed a center from a spare rim and mount the Planet Jr. flat bars to the rim.Worked fine and nobody would ever know. I have one to do now, and either getting another rim blank or use fiberglass mat and resin inside the rim to protect the tube from chafing and close up the enlarged valve hole. I thought for Simplicity,  Motor Wheel was the rim manufacturer and it was a fairly common pattern I will check my Waterloo. Good luck Mike
something like this maybe.........http://www.millertir...4-5-bolt-wheel/
Edited by Mike Unwin, December 14, 2013 - 03:29 PM.
  • Texas Deere and Horse and New.Canadian.DB.Owner have said thanks
#9 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted December 14, 2013 - 03:46 PM
Alc:  Yes, some of them do look like they would work.  I wonder if I can get them in Canada.  If not, shipping will kill me.
bread320i: Yes, it is the 3: center hole that is causing me grief.
Nato77:  I am reasonable sure they are 4.5" not 4.25".  I've had two shops measure them with the same result.  I've also measured them & the bolts are 2 5/8" & 4 1/4" center to center.
Mike Unwin: I'm looking for a second set of rims.  The existing set has a pair of 5-12 (loaded) ag tires on them.  They are getting repainted.  I have a set of 6-12 tires that I'd like to get mounted & have as spares.  I think the ones in your link would be perfect.  I hope I can find them in Canada.
  • Texas Deere and Horse and Nato77 have said thanks
#10 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted December 14, 2013 - 04:46 PM
Looks like Miller can help you out. Good Deal on finding the right rims!
#11 adamjd200 OFFLINE
adamjd200
  • 2,016 Thanks
  • 2,142 posts
Posted December 14, 2013 - 11:07 PM
You might also try checking if some rims from some farm equipment rims might fit as those look similar.
#12 nbent ONLINE
nbent
    customizer
  • 652 Thanks
  • 532 posts
Posted December 15, 2013 - 12:58 AM
i don't know what they are off of but the rims i have that came with my 317 do measure to that, and the only thing they say on them is made in usa by moto wheel
#13 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted December 15, 2013 - 10:04 AM
Car rims will fit I have seen this before.........http://ontario.kijij...QAdIdZ526220298
I talked to the lady at Miller USA and she was very knowledgeable and the only concern I had was the dreaded duty at the border.Give Lorne a call at Huron even through it was a long way from my place in Uxbridge the Tirecraft truck was going thru to Port Perry so that got me out of a jam.I bought two 16 inch tires and even through they were made in China they look great. Lorne might know a way of helping your with the shipping plus he has great tractor calendars !
Cheers Mike
