Snowplows
8 replies to this topic
#1 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted December 11, 2013 - 06:13 PM
 making a snowplow for a honda 3813 for a guy i know,
 so its going to attach/pivot at the rear just ahead of the transaxle and it uses the deck lift  to lift the plow.
 so whats the difference in a plow that mounts at front vs attaching under the rear? ive never plowed with a tractor so i wouldnt know, but my atv mounts at the rear and it plows just about anything.
 pics will come soon.
  • JRJ said thank you
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted December 11, 2013 - 06:29 PM
The rear mount would be a little tougher, and it would not wear on the front end as much. Less stress. GT's that have a plow frame that attaches on the front only are built heavy enough to withstand the stress.
  • JRJ and truckintyler have said thanks
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted December 11, 2013 - 09:12 PM
Most units with a dozer blade will either sport a blade that ties into the rear or the frame is designed to transfer the power from the drive into the plow.
  • truckintyler said thank you
#4 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted December 12, 2013 - 12:06 PM
Pushing from the rear equals better steering while pushing, but generally will push a little less( unless 4x4) and pushing off the front equals better rear traction, higher blade height , but less steering and usually better ground clearance too.
  • Talntedmrgreen, Newpaws493 and truckintyler have said thanks
#5 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted December 12, 2013 - 03:55 PM
ok so im finished.. took about 10 hours total,everthing is made from steel i had around the farm or lawn tractors that i stripped for parts long ago.
 ill try and show how i made it with the pictures, wasnt all that difficult.
 so heres how it mounts to the rear frame of the tractor, two 1" thick steel plates which i pulled from the steel pile and they already had holes in them :) . the two rods coming down are coming off the factory deck lift mechanism. works ok but its too far back so the blade is a little heavy to lift, so not for anyone with a sore shoulder. a craftsman/ayp body might work better as the lift for the deck is further ahead.
 this is the basic frame, just 1" square channel, not sure if it will hold up. but its a prototype for others i will make
 square channel at the rear of the plow bracket is where the 3/4" threaded rod runs through to the frame mounts.
pretty much the up and down pivot.
this is the underside of the front of plow bracket just some more added strength and the side to side pivot bolt i welded in.
  these are the holes for the lock pins, just some 5/8" id pipe, thought this design would be strong.
 theres the plow attached and its easy to angle just pull the 1/2" bolt and select the angle and drop the bolt back in.
  here i was pushing the 1" of snow lol. thats all i have for now so i pushed an old cub cadet around with the brakes locked and even on ice it still didnt lose traction. its -16 here today.
  all ready to go, the guy its going to is planning on making a cab for it and since its liquid cooled it can be heated with a small heater core from princess auto.
Edited by truckintyler, December 12, 2013 - 03:57 PM.
  • KennyP and CRFarnsworth have said thanks
#6 KennyP ONLINE
  • 40,943 Thanks
  • 47,132 posts
Posted December 12, 2013 - 07:13 PM
Looks like it should work fine!
#7 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted December 12, 2013 - 08:56 PM
I should have said, the plow blade was an old oil barrel, doubled up and I used the rim lock as the supports since they were already curved the same
#8 MH81 OFFLINE
  • 29,979 Thanks
Posted December 12, 2013 - 10:48 PM
Looks like a well thought out design. One thing I don't see is any bracing in the front to keep the blade frame centered under the tractor. The two points in the rear will hold for a while, but he twisting will eventually cause (plow or tractor) frame to weaken.
Just a thought. Looking forward to the cab build too. :D
#9 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted December 12, 2013 - 11:02 PM
sorry there is a side limiting bracket forgot to take a picture, pretty much attaches where the front of the deck would have attached to,  is kind of a U-shape to keep it from moving side to side,
 i wont be building the cab, but ill ask him for pictures if he does.
Edited by truckintyler, December 12, 2013 - 11:11 PM.
