* * * - - 1 votes
Bolens Qt17 Not Running Well When Warm
3 replies to this topic
#1 deek50 OFFLINE
deek50
  • 2 posts
Posted December 11, 2013 - 03:53 PM
I have a bolens qt17 with the kt17 kohler twin cylinder series II engine.  Runs good at start up but after 10-15 minutes starts to loose power, run choppy, especially under load. Replaced a head and gasket and has done this ever since.  Any help would be great.  Will really blow the snow when healthy!  thanks D
#2 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted December 11, 2013 - 04:16 PM
Hi deek50, From what I read this started when you replaced the head and head gasket?  I'm not familiar with the kt17 but my guess would be a problem with the mating surface between the head and cylinder.  Some more knowledgeable folks will be along in a little while.  By the way welcome to GTtalk.
#3 bhts OFFLINE
bhts
    Bob's Lawn and Garden LLC
  • 1493 Thanks
  • 2181 posts
Posted December 13, 2013 - 09:05 AM
Check your head bolts and make sure they are torqed correct. It could also be the coil breaking down after it runs a few mins and warms up.
  • HDWildBill said thank you
#4 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted December 13, 2013 - 10:00 AM
Ditto what Bob said above.  I've struggled with the coil breaking down before on a Kohler.  It would fire and run great for a couple of minutes, then start to sputter and act like it was having carb issues.  I put in a new carb and spent a lot of time on it, but the problem didn't go away until I replaced the coil.
