Wheel Horse Gt-14 Front Wheel Bearings
7 replies to this topic
#1 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted December 09, 2013 - 06:23 PM
While plowing yesterday (and again this evening), I heard a "squeek" sound once in a while.
When I pulled back into the barn, I jacked up the front end and spun each front wheel to confirm my thought and yep, I was right! Front wheel bearings!
I removed each wheel and 1 bearing in each wheel was shot, but not the axle or wheel...lucky me.
All the bearings, races and seals still have TIMKEN and NATIONAL numbers on them so I plan on locating repair parts tomorrow!
I will try to remember to get photos of the problem and repair tomorrow.
  • Alc and twostep have said thanks
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted December 10, 2013 - 06:11 AM
Let us know how you make out with the parts. Sometimes Stens has substitutes for this sort of thing if you can't find them at a bearing supplier.
#3 WH55 OFFLINE
WH55
  • 48 Thanks
  • 15 posts
Posted December 10, 2013 - 06:51 AM
I'm looking forward to hearing this as well, since I have 3 Wheelhorses myself. I've done  more than a bit of bearing work on various vehicles and machines, but so far I've had good look with my 3 little ponies. Of course, I've only had them for about a year. :D
#4 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted December 10, 2013 - 06:32 PM
1969 GT-14 Front Wheel Bearings.
Wheel Horse    Part WH Part #        Current Brand & Part #
Cone bearing     3370                         TIMKEN LM 11949
Bearing cup       3371                          TIMKEN LM 11910
Seal                   3373                          NATIONAL 204005
4 bearings and races, 2 seals and of course tax.....$64.52
Got the parts from TRI STATE BEARING in Jasper Indiana.
Doing the work myself, PRICELESS!
I have some photos of the work, but don't have them on the 'puter yet!
They will be forth-coming.
  • GlenPettit said thank you
#5 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted December 10, 2013 - 07:52 PM
There are many special tools needed to replace/repack wheel bearings.
Below are the specific items used for this job.....I have the professional model as well as the "back-yard" mechanic model.
You will have to guess which models I have.
1st you will need to clean all the parts you will be re-using.
You will need special tools to install the new bearing race in the wheel.
You will need to re-pack the new bearings with grease.
  • KennyP and twostep have said thanks
#6 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted December 12, 2013 - 10:30 AM
Thanks for the info. I need a set of bearing caps for one my GT14's.
Here is a pretty good price on those bearings:
http://www.drivetrai...CFWQOOgodJTwAAQ
#7 glgrumpy ONLINE
  • 8,849 Thanks
  • 8,036 posts
Posted December 12, 2013 - 04:10 PM
LIke the "special" tools used, ha!  Bought like my garage.  I bought Chinese bearing press tools and most just break, so go back to the "special" ones my self.  Have a packer, but is messy and sometimes doesn't work well on smaller bearings, so end up hand packing anyway.  I hate doing that, takes quite a while to really get grease going inside.
#8 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted December 12, 2013 - 04:51 PM
twostep, you better scarf up those bearings at that price!
They told me I was getting the agriculture discount, but maybe they were still too much!
4 bearing/race and 2 seals.
Edited by KC9KAS, December 12, 2013 - 04:52 PM.
  • twostep said thank you
