G2000 Gas Will Not Start, No Spark
2 replies to this topic
#1 Carjunkie OFFLINE
Carjunkie
  • 1 Thanks
  • 1 posts
Posted December 09, 2013 - 06:06 PM
I have a 1991 Kubota G 2000 garden tractor. I have had a problem in the past with the charge indicator light coming on and going off. Now I have no spark going to the spark plugs. Any suggestions on what the problem might be?
#2 boyscout862 ONLINE
  • 12,831 Thanks
  • 9,158 posts
Posted December 10, 2013 - 08:05 AM
Welcome to GTT. You will need to get a manual that has a trouble shooting guide and a manual for the tractor. Basically you use a wiring diagram to check voltage along the circuit that starts at the battery runs to the key switch and then into the ignition system and to the spark plug. Before anything else, make sure your battery is fully charged and that the engine ground is making good contact. Good Luck, Rick
#3 Alc OFFLINE
  • 6,883 Thanks
  • 7,459 posts
Posted December 10, 2013 - 09:03 AM
Welcome Carjunkie to GTTalk !     Can't help you much with your starting problem that Rick didn't already said  except maybe try wiggling wires in case there's a loose connection , good luck
