Lgt Project Up On Blocks
5 replies to this topic
#1 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted December 09, 2013 - 02:13 PM
My next project is up on blocks, I spent a few months last spring looking for an open sided LGT, ended up with two tractors but not sure yet if the 100 can be rebuilt or if its gonna be a parts machine for the 165, first step is to tear it down so thats gonna start now, either way I need a Ford mowing the grass by spring.
  • boyscout862, JRJ and FilledTires have said thanks
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 09, 2013 - 05:28 PM
I thought the winter time was time to use if plow if you have one.
Dick
#3 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted December 09, 2013 - 05:54 PM
Dick
LOL, I do, but those pics dont belong in the Ford forum;)
#4 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted June 23, 2014 - 02:34 AM
Doesnt look much differant now but its working well, found a deck for it, put on a steel battery cover, four tires and differant seat,  exhaust isnt finished but its functional. Mowing with it a few weeks now... not bad for a motor half full of water when I picked it up;)
#5 MH81 OFFLINE
Posted June 23, 2014 - 06:57 AM
Glad you got her going. How's the cut on those Ford decks?
Oh, and did you already post info on that exhaust? If not, could you? Looks intriguing.
#6 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted June 23, 2014 - 01:43 PM
The Ford decks typically hang so IMO that doesnt result in a really nice cut, so I lowered the front scalp rollers level with the rear wheels at cutting height... that makes it follow the ground better and it does quite a nice cut now... I have 3 50" decks so Im gonna build one of those with adjustable front swivel casters to make a true ground following deck.
The exhaust is just pieced together from the automotive section at Canadian Tire, still needs a muffler tucked up inside the rear wheel but its already alot quieter than the original burnt out muffler up front, I often spend 3-4 hrs on a mower and the noise drives me nuts so Im trying to get it away from the front of the tractor. I have about $80 invested into the 9 pieces on it so far, it barks like crazy if you stand behind the tractor but in the seat its not bad, although I still want a muffler as well.
