Dielectric Grease
14 replies to this topic
#1 oldtimer OFFLINE
oldtimer
  • 374 Thanks
  • 339 posts
Posted December 09, 2013 - 11:31 AM
I know I can use it on spark plug boots, but I was wondering....   I bought  the Predator 7Kw generator from Harbor Freight and bought a battery for the electric start.  Hooked it up with some finagling because the battery had to go under everything and the terminals end up being reversed and so the cables jussst make it. I'll get some longer ones next summer.  That's okay; I got it to fit.  I'm not fully confident how well the terminal boots will protect the terminals so I was wondering if I spread, or sprayed some dielectric grease over the connections if  that would give added protection from rain,snow, sleet, or whatever.  I'm talking OVER the boots.   Anyoone know if that's alright ?
  • Texas Deere and Horse, boyscout862 and JRJ have said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted December 09, 2013 - 11:35 AM
It should help with corrosion in the connections.
  • JRJ said thank you
#3 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted December 09, 2013 - 11:46 AM
If I'm real concerned I fill the boot with the grease before I put it on. Keeps water and other stuff out.
#4 oldtimer OFFLINE
oldtimer
  • 374 Thanks
  • 339 posts
Posted December 09, 2013 - 12:12 PM
Thanks guys.
#5 boyscout862 OFFLINE
  • 12,520 Thanks
  • 9,028 posts
Posted December 09, 2013 - 12:19 PM
Cover it good and then do something to prevent the mice from building a nest in the engine and destroying the ignition. Dont leave gas in the tank or carb. Stabil may work for awhile but after that it will need to be flushed out. Good Luck, Rick
#6 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 09, 2013 - 12:57 PM
I always use dielectric grease when installing a battery in just about everything, except like flashlights and things like that.  As stated above it will protect the terminals from quite a few things the most important is corrosion.
#7 nbent OFFLINE
nbent
    customizer
  • 652 Thanks
  • 532 posts
Posted December 09, 2013 - 03:29 PM
around here we use it for alot of conections but for our batteries we use a spray terminal protector and it has worked good for many years
  • WNYTractorTinkerer and JRJ have said thanks
#8 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 09, 2013 - 03:36 PM
I've used both with success, prefer the dielectric grease covering the entire connection, sealing it from the elements. Its a little messy, but how offend do you change the battery?
  • HDWildBill and JRJ have said thanks
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 09, 2013 - 03:40 PM
Any time I have any suspensions of a bad connection I will get the grease out and apply to the connections, so far no problems.
Dick
  • HDWildBill said thank you
#10 nbent OFFLINE
nbent
    customizer
  • 652 Thanks
  • 532 posts
Posted December 09, 2013 - 04:14 PM
we usually get any where from 4 to 6 years out out batteries on tractor we have has an 8 year old battery that starting to go bad
#11 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 09, 2013 - 06:52 PM
That why I like the dielectric, I smear a little right on the post and inside the connector. Place together and tighten, smear generous coating all over on the outside, 5+ years later change battery at the first sign of trouble.
#12 KC9KAS OFFLINE
KC9KAS
  • 5,324 Thanks
  • 4,670 posts
Posted December 09, 2013 - 07:38 PM
Use the dielectric grease. You won't be disappointed.
#13 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted December 10, 2013 - 09:47 AM
Really you can use any type of grease... Dielectric is just clean, oderless and will stand up to high temperatures. In low temp conditions (<100 F) you can even use petrolium jelly.
Basically when you use either all you are doing is displacing oxygen and/or battery acid.
#14 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted April 03, 2014 - 11:18 AM
Dielectric grease is a silicone based gel,,,  I love the stuff..  Petrolium jelly  is oil based,,as is ordinary greese.. So useing it on rubber boots,  ( plug wires )  and wires make it pron to rot..
Keeping a Batt clean is the key to a long life..and not let it over-charge or under-charge,,or freeze..
  • twostep said thank you
#15 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted April 03, 2014 - 11:47 AM
Very good point, petroleum and rubber do not play well together!
