Posting Manuals?
4 replies to this topic
#1 glgrumpy OFFLINE
  • 8,652 Thanks
  • 7,941 posts
Posted December 08, 2013 - 02:55 PM
Not sure how to post manuals. I'm not aware of how to make PDF for veiwing. Can scan the pages, but not sure how to save then??  I have a Brinley CC-1000 spring cultivator manual that is nice. Any need for that? Not sure if such thing is on here already, didn't look.  I sometimes have other stuff that I would like to post, just not into the "how" part.  Is there a Tutorial somewhere here?
  • MH81, boyscout862 and Sawdust have said thanks
#2 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,499 posts
Posted December 08, 2013 - 03:22 PM
I use a freeware program called BullZip.  It installs as a printer and allows you to print anything as a PDF.  It has a neat little feature called "append" that allows you to add pages to an existing PDF document.  Basically, you would print the first image to "Yourfile.pdf" and then print the next image using the "append" feature to the same document.
  • nra1ifer, KennyP and Sawdust have said thanks
#3 KennyP ONLINE
  • 39,090 Thanks
  • 46,297 posts
Posted December 08, 2013 - 03:44 PM
We have that manual already! It can be found here.
  • 29,970 Thanks
Posted December 08, 2013 - 08:50 PM
Thanks GL, appreciate the offer.
#5 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 09, 2013 - 10:11 AM
GlGrumpy, run this search and it will give a list of tutorals that will help you create a PDF.  Also check the documentation that came with your scanner, it should walk you through the process as well.  Once you have the PDF created here are two video's that should help you get the file uploaded.
Video1: Attaching files and uploading
Video2: Manual Video
  • MH81 and Sawdust have said thanks
