Lets See Those Winter Outfits
123 replies to this topic
#91 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted November 16, 2014 - 06:28 AM
This year will be my 69 ford 140,Will do most work with the 42" blade
Also have 38" blower for the deep heavy stuff
front mounted winch works with blade and blower
23x10.5x12 ags have chains if needed
also weight box on rear not sure what it will hold as far as pounds.
P1050472
  • Cvans, Mark K, Gabriel and 1 other said thanks
#92 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted November 16, 2014 - 09:36 AM
Nice blade set up!
#93 EricR OFFLINE
EricR
  • 699 Thanks
  • 420 posts
Posted November 16, 2014 - 09:54 AM
These 2 bad boys take care of all the snow chores around these parts.
  • jimbobbillyray, Cvans, Gabriel and 1 other said thanks
#94 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted November 16, 2014 - 10:06 AM
Thanks was a $20 special off CL.a little beat up but ,but I saved it.Was on my bolens last year.
A little fabbing for a new mount on the ford no biggey.
The ford is a hydro so snow plowing should go a little faster this year,no searching for a gear!
#95 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted November 16, 2014 - 11:22 PM
Seeing all this makes me really want a cab. It gets cold blowing snow on the Case. Very nice machines.
Eric
  • BNK said thank you
#96 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,824 Thanks
  • 2,782 posts
Posted November 17, 2014 - 09:31 PM
the 140 I had last year is gone now, so is the 2-way blade. :(   This year  I will push snow with the 318 and a 4-way blade..... :D
#97 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted November 18, 2014 - 12:55 PM
My winter outfit is the same as how I bought it.. 42" blade and an insatiable appetite for moving snow
Chains are coming soon and weights only if I have problems this year :thumbs:
  • Cvans and Gabriel have said thanks
#98 tater195 OFFLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted November 18, 2014 - 05:52 PM
Be careful with the chains on that yt16. I dont know about the hydros, but I have seen several busted axles on the gear tractor from pushing snow with chains on. The gear tractors had 3/4" axles. If your has 1" you should be fine
#99 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 18, 2014 - 08:00 PM
Here's ours.
  • IamSherwood, Cvans, EricR and 1 other said thanks
#100 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted November 18, 2014 - 10:23 PM
I guess I won't know how the traction is until I'm actually out there, but if there's not enough traction, would weights be better than chains as far as not overloading the axles?
#101 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted November 18, 2014 - 10:37 PM
The chains will mark up that nice concrete. If you can do wheel weights and fill your tires you may get away without chains. I use chains with carbide bars and have left a lot of marks on concrete and blacktop.
Geno
#102 richwoodrocket OFFLINE
richwoodrocket
    16 year old JD lover
  • 147 Thanks
  • 177 posts
Posted November 18, 2014 - 11:29 PM
Edited by richwoodrocket, November 19, 2014 - 11:08 PM.
  • Cvans and 1oldbuzz have said thanks
#103 TomLGT195 OFFLINE
TomLGT195
  • 3,834 Thanks
  • 2,816 posts
Posted November 19, 2014 - 10:24 PM
Here's my new rig, I don't have the 145 with the plow anymore . Didn't see a need now that this is done. I still have the little snowblower though.
The 48" blower on back is PTO driven ( homemade) with an electric angle for the chute. And the bucket is 48" too.
Tom
Edited by TomLGT195, November 19, 2014 - 10:26 PM.
  • IamSherwood, Cvans and 1oldbuzz have said thanks
#104 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted November 19, 2014 - 10:35 PM
Got my first chance to push snow with the Ford YT! Handled 5 inches of fresh powder with ease!
I was also pleasantly surprised to have absolutely no problems with traction. Looks like I'll be holding off of chains and weights. Having a nice flat concrete driveway probably helped  :thumbs:
Looking forward to more snow!!
  • Cvans, TomLGT195, Gabriel and 2 others have said thanks
#105 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted November 20, 2014 - 08:15 AM
Just a heads up.If its your first time plowing?
You have to PUSH the snow further than needed.Makes room for the next batch.
Them frozen snow pile don't move so easy.
  • Cvans and aevansgatech have said thanks
