Eliminating Blade From A Riding Mower.
21 replies to this topic
#1 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted December 05, 2013 - 09:45 PM
I've been redoing an old Craftsman vertical shaft riding  mower with the intent of letting the grand children ride it  I'm thinking of removing the blade for safety.  Question is how this will affect the engine operation, since its rotating mass acts as a flywheel.     Should I replace it with something of equal weight?  (such as a small pulley or something fabbed on the lathe)    Or would it need to be heavier to compensate for the inertia generated by the end of the spinning blade?  (24" blade)  Any ideas?  Rick
Edited by CRFarnsworth, December 05, 2013 - 09:52 PM.
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted December 05, 2013 - 10:04 PM
Nope, It won't bother the engine at all.
The extra rotating mass is just drag.
The engine has a big enough flywheel to run fine.
  • Alc, CRFarnsworth and boyscout862 have said thanks
#3 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted December 05, 2013 - 10:08 PM
you can remove the belt to the deck, that is if it has a belt
  • CRFarnsworth and boyscout862 have said thanks
#4 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted December 05, 2013 - 10:09 PM
I wondered if i was over thinking the situation.  Rick
#5 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted December 05, 2013 - 10:12 PM
It is a vertical shaft engine, with the blade attached to the crankshaft. It does have a belt to the transmission but I need that one Rick
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 05, 2013 - 10:15 PM
Rick, all I know is that sometimes on vertical shaft mower engines the blade does act like a counterweight.  I know many push mower engines will shear a key if it is started without a blade on it.
Ben W.
  • Alc and CRFarnsworth have said thanks
#7 WHdbJD OFFLINE
WHdbJD
  • 685 Thanks
  • 515 posts
Posted December 06, 2013 - 05:44 AM
You cant overthink things when it comes to grandkids and safety.
#8 MH81 OFFLINE
Posted December 06, 2013 - 12:24 PM
Rick, it will be harder to start and more of a chance of stalling without it. Low rpm's could cause issue also and, as has been mentioned, shearing keys can happen especially with a backfire while starting.
A rotating mass of any kind will help, just keep in mind that anything under there that is turning can grab the jump rope left in the yard and wrap it up faster than scat.
  • CRFarnsworth said thank you
#9 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted December 06, 2013 - 06:20 PM
Been thinking i may just turn the blade upside down and block off the discharge chute.  Also leave the deck as low as possible.  Rick
#10 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted December 07, 2013 - 07:49 AM
This is still not the safest way to do it.   .....The upside-down blade will still mangle a hand or foot.  .....The blocked discharge chute will not prevent a hand or foot from going under the deck elsewhere.  .....The lowered blade/deck will be more likely to cause the blade to hit humps, thus shearing the flywheel key.
You mentioned possibly putting a pulley onto the crankshaft.  ....This is a good way to add mass.  ....A large pulley is better than a small pulley.
You also mentioned a lathe, so if you have access to one, a round disk would be good as long as it is securely fastened to the crankshaft.
  • MH81 and CRFarnsworth have said thanks
#11 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted December 07, 2013 - 08:29 AM
The way I see it, If the tractor runs with the blade disengaged, it will run fine without it.
I have a 15.5 B&S that runs like a swiss watch with out the blade or deck attached
A garden tractor is not a push mower.
#12 MH81 OFFLINE
Posted December 07, 2013 - 11:27 AM
This unit is like a push mower. The blade is directly attached to the bottom of the engine.
#13 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted December 07, 2013 - 11:33 AM
I stand Corrected, I guess the only way to find out is to try it.
I've never seen a riding mower that you couldn't disengage the blades.
#14 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted December 07, 2013 - 01:52 PM
Near as i can determine the rider is a 4 hp model from 1960.
Might have to put some Farmall decals on it!
Edited by CRFarnsworth, December 07, 2013 - 01:57 PM.
  • MH81, IamSherwood and sacsr have said thanks
#15 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted December 07, 2013 - 01:55 PM
I found a pulley that is  half again the weight of the blade.   Will use that as a starting point and do some trial and error.  hopefully not much error!  Rick
