Making My Snow Plow Wider
23 replies to this topic
#1 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted December 05, 2013 - 07:13 PM
Power Kings are great for plowing snow, they are strong, heavy, and have steer brakes. The only downside is that the snow plows are 48 inches wide. For a normal GT this is fine, but a PK with the wheels turned out is around 48 to 50 inches wide. Then angle the blade, or turn and you will be running over more snow then your are pushing! The PKs handle a 48 inch plow like nothing, and they can handle a wider plow without a problem. I am using two 4 foot blades to make one that is 5 1/2 feet wide.
In the spring I bought a plow at a show in CT for $30. Once I had taken everything off of it, I used the plasma cutter to snip 9 inches off of each side. There is still plenty left in the middle piece that i could widen another plow too.
4474738E-F640-4CD5-ACC2-ECC354FE2789-236
A little bit of grinding to get the fit-up I wanted and I had the sides welded to another blade for a total of 66 inches. On the bottom edge it looks like it does not line up, that is because the edge on the blade I cut the ends off was not replaced when it needed to be. Because the edge was not replaced, some of the plow has also been worn down.
I am pretty much done with it, I have to get shielding gas tomorrow and do some small finishing touches. Then, make a new wear edge and slap some paint on it.
  • MH81, Alc, IamSherwood and 9 others have said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted December 05, 2013 - 07:25 PM
Ryan, that is really going to work nicely for you. What will you use for the cutting edge?
  • Ryan313, boyscout862 and JRJ have said thanks
#3 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted December 05, 2013 - 07:26 PM
I am just going to use a piece of 1/4" flat stock, either 1 1/2 or 2 inches wide.
  • Texas Deere and Horse, boyscout862 and JRJ have said thanks
#4 ricky racer OFFLINE
ricky racer
  • 39 Thanks
  • 29 posts
Posted December 05, 2013 - 07:29 PM
Sweeeeeet!! Very nicely done!! :thumbs:  We need to see pictures of it pushing snow now. You know we like pictures.
  • Ryan313 and JRJ have said thanks
#5 IamSherwood OFFLINE
  • 8,390 Thanks
Posted December 05, 2013 - 07:35 PM
Nice Ryan. That otta keep your tires out of the snow.
How about putting some wings on it too, so snow doesn't spill
out so easily.
#6 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted December 05, 2013 - 07:42 PM
What did you do for support on the back side.    66" Now thats a plow!
#7 Ryan313 OFFLINE
  • 3,360 Thanks
  • 5,228 posts
Posted December 05, 2013 - 07:48 PM
From the factory, along the top edge is a piece of 3/8" flat stock that supports it. Other then that there is not much there. I did put a V-groove on the front of the blade so that after I ground the weld flush it would still have strength from that weld. Plus, I put two passes along the backside of the seam. The weld penetrates all the way through the blade and I don't see why that will not be enough to hold it.
  • boyscout862 and JRJ have said thanks
#8 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted December 05, 2013 - 08:12 PM
 Nice work Ryan, that should push some serious snow! :thumbs:
Matt
#9 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted December 05, 2013 - 08:19 PM
Nice work!  That will make for a much more efficient worker.
I had picked up a PO modified Simplicity blade, with this same mod.  When I first saw it, I wondered if it would hold against a snag.  The fabricator added straps behind the welds, to support the joint, and I cannot imagine it ever breaking.  The cutting edge was 3/8"
  • Alc, trowel, Ryan313 and 2 others have said thanks
#10 ricky racer ONLINE
ricky racer
  • 39 Thanks
  • 29 posts
Posted December 05, 2013 - 08:21 PM
I added an extension to the top of the blade on my Cubs blade, that and a power angle. The extension really help keep the snow from tumbling over the top of the blade. The Cubs blade is 54" long.
#11 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted December 05, 2013 - 08:49 PM
Nice job Ryan !  Will you be adding any type of shoes ,runners  skids, (  you know what I mean lol ) ?
#12 Ryan313 ONLINE
  • 3,360 Thanks
  • 5,228 posts
Posted December 05, 2013 - 08:58 PM
Thanks! I will be using the original type shoes for this plow.
  • Alc, boyscout862 and JRJ have said thanks
#13 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted December 05, 2013 - 09:40 PM
That looks great! Nice work! You will clear the snow a lot faster now!
Geno
#14 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted December 06, 2013 - 06:24 AM
Looks good id like to add a foot to our 445 but the hydraulic quick attach front blades are pretty pricey 54 inch plow works pretty good.
#15 KennyP OFFLINE
  • 37,391 Thanks
  • 45,446 posts
Posted December 06, 2013 - 07:13 AM
That should do fine, Ryan!  Didn't take you long either!
  • JRJ said thank you
