Gggrrr, This 8N Is Making Me Pull My Hair Out.
#16
OFFLINE
Posted December 05, 2013 - 11:31 AM
#17
ONLINE
Posted December 05, 2013 - 12:22 PM
It's a pretty consistant lugging sound. Every once in a while it sonds like starts spinning faster, then back to the same slower lugging sound.
#18
OFFLINE
Posted December 05, 2013 - 06:50 PM
If I had a gauge.....
My apologies. Santa's coming soon, maybe he'll stop by HF and get you one. A VOM and comp tester are a must for engine diagnostics.
Mike
- TAHOE said thank you
#19
ONLINE
Posted December 05, 2013 - 09:19 PM
Mike
I used to just borrow my GM mechanic neighbor's gauges along with many other tools, he moved last year
#20
OFFLINE
Posted December 05, 2013 - 11:11 PM
Marty, Sorry to late on this, but I would bet money that the rings and maybe a valve is stuck, not allowing the engine to create enough vacuum to draw the fuel mixture into the engine. I would soak all 4 cylinders with MMO for a few days and then add a little gas to each cylinder to see if it hits.
- Cvans said thank you
#21
OFFLINE
Posted December 06, 2013 - 07:24 AM
Getting some kind of oil into the top end of the cylinders before proceding is your best bet at this time . Otherwise cracked piston rings could result . Should have been a first . Good luck .
#22
ONLINE
Posted December 06, 2013 - 09:57 AM
Thanks guys, I never thought of oiling rings, as many Small block chevys I've started after yrs of sitting, should've came to mind to soak pistons in oil beforehand.
When he said it ran I just quit using it, just rang in my mind clean carb and it should fire.
I'm hoping it's not a valve, I have no plans on going into this motor any deeper.
It will be this next week before I get back out there so maybe a while before I update again....the white death is almost upon us today!
#23
ONLINE
Posted December 06, 2013 - 01:46 PM
I would toss some ATF into the cylinders and let that go to work on the rings. It is thinner than oil so it will work down into the rings.
#24
ONLINE
Posted December 10, 2013 - 09:57 AM
Got any further on this?
#25
ONLINE
Posted December 10, 2013 - 12:20 PM
Nope too much snow and I have been under the weather sick wise, no energy.
Thanks for asking!
#26
OFFLINE
Posted December 11, 2013 - 07:22 AM
#27
ONLINE
Posted December 11, 2013 - 09:40 AM
Thanks....sinuses leading to drainage = sore throat. Plus I wrench my back somehow on Sunday or Monday, middle of my back is in knots right now and I hate this cold weather (2* F this morning) and 8"s of snow on the ground.
Ibuprofen and Mucinex
- Texas Deere and Horse said thank you
#28
OFFLINE
Posted December 11, 2013 - 12:10 PM
Funny, in our youth, it was s, d, r & r... Now it's I, m, r & r (rest and recovery)
- Alc and TAHOE have said thanks
#29
ONLINE
Posted December 11, 2013 - 01:01 PM
Marty, hope you get feeling better my friend. It's good you're trying to help out a neighbor, but sometimes ya gotta take care of yourself. If the tractor is a bit too far gone, then cut the cord & release yourself from it.
#30
OFFLINE
Posted December 12, 2013 - 09:02 AM
I had the exact same thing (sore throat) going on last week. Finally back to normal and had a chance to work on my project.
Not much to add to your 8N problems, it sounds like the bases are covered already. But I can sympathize...
I learned a lot of "vocabulary" from my dad because of our family's 8N when I was a kid! It seemed to frequently have starting issues.
