Anyone Here Able To Build One Of These For Me?
31 replies to this topic
#31 Texas Deere and Horse ONLINE
  • 14,898 Thanks
  • 15,518 posts
Posted December 05, 2013 - 03:07 PM
Texas Deere and horse, do you know of any kind of hydro pump that would attach to the front shaft coming out of a K341 16hp Kohler to help drive a seperate hydro setup?
If I go to the extreme with this little tractor I would dedicate its use for things that can be run using hydro.
Or, do you think that the Allis 716h's hydro pump would be enough to run the 3 point on the back and when needed lift and lower the front dozer blade when attached. The two things would not be used at the same time.
I really really need to come up with some way to make a hydro wood splitter.
I need to be able to do so many different things but don't know exactly how to go about it and I would have to slowly piece things together as my budget allows.
The A/C will handle the 3pt and front blade with it's own Hydro. You can also mount a pump on the front of the other tractor and couple it direct or belt it off the PTO clutch, I would do it off the clutch so you aren't spinning the pump at start up.
#32 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted December 05, 2013 - 03:21 PM
What is your ideas on making a 3 point setup for the Allis?? Could a factory rocker shaft be put on the back up high to move the lift arms??
