Grader Blade Build
grader blade ff20 implements home made
70 replies to this topic
#1 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted December 03, 2013 - 02:42 PM
I cut apart the oxy/actylene rack I got from Aaron some time back. I needed to see what the metal would look like under the tractor. I won't be starting this right away. But I needed something to do for the next few days while the weather was nasty. So, after getting some measurements, I can work up a drawing to see how this will fit. I plan to use the deck lift for this. I have 3.5" of lift there, not sure what that will work out to with the pivot points as yet. There is plenty of room under the tractor @ 14.5". Blade is only 8" tall.
Here's a sneak peek at a chunk under the FF.
It will be about 5' wide, with the ability to angle both fwd/back & left to right. Here's hoping it will work!
  • Alc, Texas Deere and Horse, boyscout862 and 4 others have said thanks
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 03, 2013 - 03:08 PM
Kenny it looks like you may have a good plan, I think it will work. Good luck with the remaining portion, you'll have that done in no time the way you are going now, and then what.
Dick
Edited by JRJ, December 03, 2013 - 04:24 PM.
#3 Michiganmobileman OFFLINE
Posted December 03, 2013 - 03:39 PM
Looks like a good project, always nice to have something to keep ourselves busy.
  • KennyP and JRJ have said thanks
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 03, 2013 - 04:24 PM
And out of trouble.
Dick
#5 Texas Deere and Horse ONLINE
  • 14,792 Thanks
  • 15,492 posts
Posted December 03, 2013 - 05:04 PM
Kenny, it appears that you have more then enough room to make it work. Should be a great addition to your tools.
#6 MH81 OFFLINE
Posted December 03, 2013 - 05:17 PM
Is this something that they had available for the FF's or is this a KP original?
#7 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted December 03, 2013 - 05:42 PM
That blade looks like it is a good size for the FF, I am sure it will end up being a great attachment to have!
#8 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted December 03, 2013 - 06:08 PM
This will be another KTP special, Alan! (KTP = Kenny's Tractor Port)
I'll start plugging the dimensions into the drawing tomorrow to see what works. I'm not sure if I can 'swing' it off the rear mower attachments, but would like to. That would put the pressure pushing on the mounts. We'll see! This may be an all winter build as I have to look at temps to work out there. But, if I can get it all figured out, it will go quick from there. Getting the swivel and tilt figured out will be the most fun.
  • JRJ and TomLGT195 have said thanks
#9 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 03, 2013 - 06:45 PM
Ok, an Oxy/Acetylene rack converted into a grader blade. :worshippy1:
What's next Kenny, are you going to convert your cement
mixer into a snow blower? :smilewink:
Looking forward to the progress updates. :thumbs:
  • KennyP, Dieselcubmike and JRJ have said thanks
#10 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted December 03, 2013 - 06:52 PM
Don't have a cement mixer, Will!
  • JRJ said thank you
#11 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 03, 2013 - 07:24 PM
Well why not Kenny.
Dick
#12 MH81 OFFLINE
Posted December 03, 2013 - 07:27 PM
Kenny, you're going to have to find an inner tube, three spatulas, a chunk of garden hose and an old charcoal grill so you can build one...
  • IamSherwood and KennyP have said thanks
#13 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
But if he did......................
#14 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted December 03, 2013 - 07:33 PM
Is that what yours is?
#15 MH81 OFFLINE
Posted December 03, 2013 - 07:34 PM
I don't have one either Kenny.
Also tagged with one or more of these keywords: grader blade, ff20, implements, home made
