Bolens 1886 Forklift Refurb
208 replies to this topic
#136 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted April 17, 2014 - 08:44 PM
:camera:   ??????????     :tapping_fingers:
Ahem.
I didn't realize I was running this far behind on pictures.  :D
Here's the most recent.  I had to do some modifications, since the hood wasn't quite right.  I found one at a local junkyard that did the trick.  I decided it was simpler to repaint the rest of the tractor to match the hood.
See what you think.   I think it really helped it.
Ben W.
  • OldBuzzard, IamSherwood, KennyP and 2 others have said thanks
#137 nbent OFFLINE
nbent
    customizer
  • 680 Thanks
  • 540 posts
Posted April 17, 2014 - 08:59 PM
:thumbs:  :thumbs:  :thumbs:  :thumbs:  i like it
#138 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted April 17, 2014 - 11:48 PM
Oh the HORROR!!!!!
A poor unsuspecting Bolens, painted in the hideous colors of a clearly inferior tractor.  :(  :(  :(
  • LPBolens and superaben have said thanks
#139 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 18, 2014 - 10:26 PM
Ahem.
Ben W.
:bigrofl:  :bigrofl:
Did Willie get the lift part of it?
#140 UncleWillie OFFLINE
  • 16500 Thanks
  • 9061 posts
Posted April 18, 2014 - 10:33 PM
:bigrofl: :bigrofl:
Ssshhhhh
  • superaben said thank you
#141 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 18, 2014 - 10:42 PM
Ssshhhhh
OKAY......ssssssshhhhh
#142 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted April 18, 2014 - 11:04 PM
:bigrofl:  :bigrofl:
Like Bill said, it depends on what the definition of "it" is.
Ssshhhhh
Pipe down, will ya?
Ben W.
#143 hatedge OFFLINE
hatedge
    Beer Guzzling Canuck
  • 292 Thanks
  • 577 posts
Posted April 20, 2014 - 09:03 PM
SOoooooo? what happening?
Ben, you cant expect us tractoholics to just sit and wait weeks without pics do ye?
Come on mate... just one more fix :worshippy1:
Edited by hatedge, April 20, 2014 - 09:04 PM.
#144 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted April 20, 2014 - 09:49 PM
Alright, I hear you.  :D
Watch carefully in the next minute or two.
Ben W.
  • hatedge said thank you
#145 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Since I am about to get tarred and feathered for not sharing the news, I suppose I ought to do something.
It really has been a "nothing to show" kind of time the past few weeks.  Nothing exciting, like a tractor changing colors in one day from splotchy paint, to bare steel, to primer, and then to the final coat.  Its a lot of touch up and reinstall.
One exciting thing was that I was able to finally get the tractor off the expensive stands it has sat on for a few months.  Remember these?   The price was $50 a pair, I'll knock this used set off for $25 (50% savings!!) if you buy it tonight.
Dave was concerned about traction.  Once he sent me these tires, I realized that his fears are now groundless.
I think we gained ground clearance, which is a big plus.
The new front tires are much wider.  I think they will help bear the forklift much better.
I set the fender on the tractor just for kicks and giggles.
The machine shop who sandblasted it cleaned up the injured corner where the drive pedal must have met it "back in the day."  The only spot left is the rip around the bolt.  A wide fender washer will hide most of that, anyway.  Welding it would probably tear it up worse, anyway.
The hood turned out excellently.  There's one spot on top that shows up where the metal had pitted.  And a couple dings that didn't beat out all the way.
I think the red and black look great together.
Final parts waiting to be installed:
Ben W.
Edited by superaben, April 20, 2014 - 09:50 PM.
  • MH81, OldBuzzard, wvbuzzmaster and 4 others have said thanks
#146 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted April 21, 2014 - 02:11 AM
 Looking better and better  :thumbs:  :thumbs:
I wanted those tires for extra ground clearance and for their load carrying ability.
The rears are 27" instead of the original 26", and I'm not so sure that the ones on it were a full 26" to start with.
The fronts are 18" and I think the originals were 16".
With that low slung sub-frame for the lift, any extra ground clearance is definitely a plus.
As a bonus, they definitely give it a 'ready to work' look as well  :D :D :D
  • IamSherwood, sacsr and superaben have said thanks
#147 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted April 21, 2014 - 05:51 AM
That's looking real good, Ben! Coming along nicely!
#148 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted April 21, 2014 - 06:24 AM
Good looking machine that is getting better.
#149 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 21, 2014 - 06:35 AM
Looking good. What are those front tires? Vredstein?
#150 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted April 21, 2014 - 08:13 AM
Those are the 6-ply 18x8.50-8 V61s.  They have a load rating of  1130 lb. @ 45 psi.
They are the same as the ones on the HDT1000, and should be more than adequate for any load that I put on the lift  :D :D :D
  • IamSherwood and superaben have said thanks
