Rf 110 With Fel?
6 replies to this topic
#1 ricky racer OFFLINE
ricky racer
  • 39 Thanks
  • 29 posts
Posted December 02, 2013 - 08:58 PM
I'm just thinking here, but has anyone ever seen a RF 110 with a front end loader? I am wanting a garden tractor with a FEL and may end up making my own. I have a '66 110 and was just thinking, hmmmm.
My main question is would the transaxle hold up with a weight box mounted on the rear of the tractor? I have wheel weights but think I'd need a weight box too. If it's been done before and you have pictures, I'd like to see them.
Give me your thoughts.
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted December 02, 2013 - 09:05 PM
Ricky,
I don't have any front end loaders, but I know Kenny (Littledeere) has a 1967 110 with I believe a Johnson loader on it. I'm sure he'll be along shortly to show you a picture of it.
  • ricky racer said thank you
#3 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted December 02, 2013 - 09:23 PM
Ricky
I have a 73 110 with a Wright-Way FEL on it.  I have over 100 lbs on the hitch and concrete wheel weights 50 lbs on each side and I have no problems with the transaxle.
on the 73 my front axles are 1" not the 3/4", plus my front tire are 4 ply.  you might have to beef up the front end of your tractor, because of the weight that you are lifting
I make front fork for my FEL to turn my compost pile and it still can lift the rear end off the ground, so there can be a lot of weight that goes to the front axle
  • johndeereelfman, boyscout862 and ricky racer have said thanks
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted December 02, 2013 - 09:27 PM
My FIL's brother has a '64 or '65 that has had a loader on it since it was new. MY FIL hasn't talked him out of it yet, but it's not for a lack of trying.
  • boyscout862 and ricky racer have said thanks
#5 Littledeere OFFLINE
Littledeere
  • 1,658 Thanks
  • 1,487 posts
Posted December 02, 2013 - 10:10 PM
Lets see I think I have some pics
I would say you should not have issues with the rear but the but the front stuff is a little lite
even though many used them for years kind of hard on your arms and the tractors spindles
I would say you should have at least 300 to 400 lbs added to the rear
  • johndeereelfman, boyscout862, superspeedex and 1 other said thanks
#6 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted December 02, 2013 - 10:50 PM
You need to put one on a "real" GT. A Cub Cadet. :poke: :rolling: Just kidding.
#7 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted December 02, 2013 - 10:53 PM
I think the OP is looking for something that is capable of doing work, not a lawn ornament.
:poke:
jk
