Correct Piston Size For K301 Rebuild
8 replies to this topic
#1 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted December 02, 2013 - 08:07 PM
I have a cub cadet 129 I have been working on for awhile now. Engine needs to be bored .030 over. I ordered a piston assembly for a k301 from Tulsa engine warehouse that is .030 over. The new piston is about 1/8 too big. The machine shop measured the cylinder diameter and it matches to the specifications for a K241! The engine block is clearly stamped K301. Measuring the stroke it appears longer than a K241. So, is this a Cub Cadet Kohler? The new piston is also deeper than the original. What do I need to get this rig going again?
  • bowtiebutler956 said thank you
#2 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted December 02, 2013 - 09:15 PM
Kohler k241 should be 3.250 bore x 2.875 stroke
The K301 is 3.375 bore x 3.250 stroke.
What size have You got?
Joe
  • Jkrogers said thank you
#3 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted December 02, 2013 - 10:34 PM
The block is stamped "K301" but the cylinder measures to a K241.
#4 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted December 02, 2013 - 10:57 PM
OK a while back on a Cub Cadet site I belong to there was some discussion about the K301 stampings on some of the Kohler blocks .
The K241 and K301 are the same block , they are just bored to a different diameter .
Long story short there are 10 hp Kohlers out there that have  K301 stamped on the block .
Some of the Kohler block castings have a lot of metal in them and I once had a 10 hp block that was so badly pitted from water standing in the cylinder , I had it bored all the way out to 14 hp std.
#5 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted December 02, 2013 - 11:04 PM
 Jlaws, is correct. You have a K241, with the more desirable thick wall K301 block. You will need to get a .030 piston for a K241.
Matt
  • Jkrogers and Jlaws have said thanks
#6 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted December 02, 2013 - 11:14 PM
Thanks guys that makes sense. This engine came out of a 129.
#7 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted December 02, 2013 - 11:26 PM
Jkrogers , Your engine has probably been changed at one time or another .
I bought a 169 off CL a few years back , and when I went to pick it up I discovered it had a 12hp engine instead of the 16 hp that was supposed to be in it . The model/serial number tag identified it as a true 169 .
You run into that a lot when buying 40 year old GT's that have gone through 3 or 4 previous owners .
  • Jkrogers and boyscout862 have said thanks
#8 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted December 03, 2013 - 07:09 AM
You should download the manual from our manuals section. I find that it is better to not order parts until the machine work is done. With the cost of shipping, I try to do a couple at a time. Good Luck, rick
#9 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted December 03, 2013 - 08:47 AM
One problem I have had with the engine is that someone converted it from the original starter generator system to a stator. So, it had a different flywheel and shroud and I don't have those original serial numbers or any serial numbers so it is always a guess. I have got it back to the original starter generator system. I really wish I had the original numbers for it.
I guess we will go with a .030 over k241 cylinder.
