Differences Between J B I & J B I I
37 replies to this topic
#16 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,370 Thanks
  • 3,323 posts
Posted December 18, 2013 - 12:35 PM
Another thing I have noticed is the front spindles are different. Will try to get a picture at some point today. JBI has an extra arm (to mount the steering rod too) welded on the drivers side and has "stop" welded on the arms as well.....JBII does not have either of these.
#17 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted December 18, 2013 - 05:23 PM
Scott, I got some photos of that area. The JB II use a whole different geometry set up for steering then the JB I does.
IMG_20131218_155701_269.jpg IMG_20131218_160114_782.jpg IMG_20131218_160455_204.jpg IMG_20131218_160748_402.jpg
  • KennyP, sacsr and twostep have said thanks
#18 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted December 18, 2013 - 05:31 PM
Here's the photos of the Parking brake setup.
JB II uses a rod that comes thru the seat support to set the brake
JB I Uses a cable (missing on mine) to operate the P brake from the tool box mounted over that same side fender.
  • KennyP and sacsr have said thanks
#19 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted December 18, 2013 - 05:52 PM
I think they used the same front axle beam, just reversed it on the JB II. You can see that the stops are on the back of the axle on the JB II and in front and trimmed off on the JB I.
JB II underside
JB I
Spindles  JB I             JB II
  • olcowhand, KennyP and sacsr have said thanks
#20 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,370 Thanks
  • 3,323 posts
Posted December 19, 2013 - 09:51 PM
It has been brought to my attention the way the steering box is mounted/setup is different. My picture has the left side cover off, but yours Brian looks more like a box around the gear box than mine. Also note my decals are not located the same place as yours ImageUploadedByTapatalk1387507855.173690.jpg ImageUploadedByTapatalk1387507892.546483.jpg
Edited by sacsr, December 19, 2013 - 09:53 PM.
#21 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted December 19, 2013 - 10:46 PM
Scott, Mine is a lot different then yours. I will get more photos of mine in that area so we can compare.
  • olcowhand and sacsr have said thanks
#22 twostep OFFLINE
twostep
    Rockstar
  • 1,933 Thanks
  • 2,514 posts
Posted December 20, 2013 - 12:04 AM
I don't know if this is common knowledge to you BH folk but I notices that the floorboards are mounted different.
#23 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,370 Thanks
  • 3,323 posts
Posted December 20, 2013 - 06:11 AM
Good eye! My JBI looks like the second picture
#24 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,370 Thanks
  • 3,323 posts
Posted December 20, 2013 - 06:46 AM
Here's 3 better photos of the gearbox used in the JB"s.
attachicon.gifIMG_20131219_095138_089.jpgattachicon.gifIMG_20131219_095206_865.jpgattachicon.gifIMG_20131219_095217_447.jpg
Brian my gear box does not look like this......that may be why the different mounting setups. Anyone with JB's might want to see what theirs looks like and let us know. Be interesting to see when this change was made....may help date your JB1 if it is like your JBII.
#25 olcowhand OFFLINE
  • 37,225 Thanks
  • 30,213 posts
Posted December 20, 2013 - 08:33 AM
Mine as well...I'll try to get pics today.
#26 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted December 20, 2013 - 04:24 PM
Here is better photos of my steps and their differences.
  • sacsr and twostep have said thanks
#27 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,370 Thanks
  • 3,323 posts
Posted December 22, 2013 - 05:34 AM
There are two tractors on the BH yahoo group forum that have the same steering gear setup as mine, but I could not find where the serial numbers were listed for them. Also need to look at the front pto set ups. Jack and I both noticed their is some differences there as well.
#28 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,786 Thanks
  • 2,298 posts
Posted December 22, 2013 - 08:53 PM
Ill snap some photos of mine soon
  • sacsr said thank you
#29 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted January 15, 2014 - 03:56 PM
OK guys, I'm having trouble figuring this out. Both JB's frames measure right at 72". In the manuals section there are 3 different files showing the the JB-I is overall 86" and the JB- II is 76" overall. I can see about 5" in the front axle and tire sizes, but unless BH was measuring the 3pt hitches also, my machines don't add up to these numbers.
Here's one of the files I got this info from.
http://gardentractor...cs-attachments/
#30 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted January 15, 2014 - 03:59 PM
I can't help as I don't have the PTO jack shafts for either one of my JB's
