Differences Between J B I & J B I I
37 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,665 Thanks
  • 15,449 posts
Posted December 02, 2013 - 02:01 PM
Started to do a little checking on the wheel base differences between the 2 and found that the frames are the same length, but the front axles are in different locations. The JB I has a set back of 6 1/2" from the front of the frame and the JB II has a setback of 11 1/2". So far besides the rear hubs, this is the only difference I have found.
  • KennyP, sacsr, boyscout862 and 2 others have said thanks
  • 14,665 Thanks
  • 15,449 posts
Posted December 03, 2013 - 10:54 AM
This is to answer Scott's wheel base question.
Here is some pictures of the axle location on the tractors.
                JB I                                      JB II
                JB I                                      JB II
  • olcowhand and sacsr have said thanks
#3 KennyP ONLINE
  • 35,091 Thanks
  • 44,112 posts
Posted December 03, 2013 - 10:57 AM
So the axle mounts are welded in there? Frame side rails seem to be the same.
  • 14,665 Thanks
  • 15,449 posts
Posted December 03, 2013 - 11:07 AM
There is a difference in the side boxes also, not sure why they have different amounts of slots and different lengths of slots?
These are the 2 left side swing open boxes, 2 slots verses 1?
These are the 2 right side control boxes. Both have 3 slots but different lengths?
  • 14,665 Thanks
  • 15,449 posts
Posted December 03, 2013 - 11:19 AM
Kenny, Both frames are the same length, and the cross member is welded in.
                   JB II                                JB I
  • sacsr said thank you
#6 KennyP ONLINE
  • 35,091 Thanks
  • 44,112 posts
Posted December 03, 2013 - 12:25 PM
So if someone needed a JB I frame, you could use the II, just move the axle forward!
  • 14,665 Thanks
  • 15,449 posts
Posted December 03, 2013 - 12:41 PM
Yes they could, so far that's the only difference I have found in the 2 tractors.
#8 olcowhand OFFLINE
  • 38,809 Thanks
  • 30,702 posts
Posted December 03, 2013 - 03:48 PM
Brian, on the box with the 3 slots, with the outside slots being longer, it would appear someone has cut the slots longer on the bottom end.  Especially the far right one looks not to be a good round end of that slot, making me thing someone adapted another cable control & had to cut the slit further.  On that one I can pretty much make out where the end of of that slot originally ended.
#9 olcowhand OFFLINE
  • 38,809 Thanks
  • 30,702 posts
Posted December 03, 2013 - 03:54 PM
Look at the right side slot where the arrow points.  Seems I can make out the start of the round original bottom of the OE slot.  The left arrow points to where the OE bottom slot was.  Looks like the cut below that point is a little rough compared to the top.
#10 Texas Deere and Horse OFFLINE
  • 14,665 Thanks
  • 15,449 posts
Posted December 03, 2013 - 04:06 PM
Daniel, that one is the one I got from you. Did you happen to cut it?
#11 olcowhand OFFLINE
  • 38,809 Thanks
  • 30,702 posts
Posted December 03, 2013 - 05:40 PM
No, but dang ear everything else on that entire tractor had been cut, torched, or welded!  It's the JB that I built Hogzilla from.
#12 Texas Deere and Horse OFFLINE
  • 14,665 Thanks
  • 15,449 posts
Posted December 03, 2013 - 05:47 PM
LOL, yeah I remember you telling me that. It sure does look good now though!!
#13 IamSherwood OFFLINE
  • 8,390 Thanks
Posted December 03, 2013 - 06:05 PM
Damn you've got good eyes.
#14 olcowhand OFFLINE
  • 38,809 Thanks
  • 30,702 posts
Posted December 03, 2013 - 07:11 PM
I've got good bifocals!  :smilewink:
  • Texas Deere and Horse and Titus have said thanks
#15 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,405 Thanks
  • 3,345 posts
Posted December 15, 2013 - 06:47 AM
The difference in the slots on the two models is because on the JB1 the parking brake is on the left had side floor. The left side box just has the box release lever and the knob to use to move the box. On the JBII the extra slot on the box is because they moved the parking brake off the floor to the box.
Below is a picture of the JBI parking brake
  • olcowhand and Texas Deere and Horse have said thanks
