Mf1650 W/snowblower Needed Rear Counter Weight.
12 replies to this topic
#1 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 01, 2013 - 06:11 PM
The other day I got the 1650 ready for snow blowing duty.
I took off the AGs and put on the loaded chained turfs, and
75 lbs. per side wheel weights. There's 7 gallons of wiper
fluid in each tire. So, that's about 290 lbs. total extra
weight. After hanging the blower, I took it for a test run.
I didn't like the way it was steering with the blower up.
Too much weight up front, making it hard to turn, which
has got to be abusive to the steering box.
So, this morning I welded up an ugly bracket to fit on the
3pt.
Then I draped some large chain I had over the bracket.
From a chain weight table I found online, I figure that the
chain weighs about 350 lbs. That solved the heavy front
end problem.
  • olcowhand, Texas Deere and Horse, KennyP and 1 other said thanks
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted December 01, 2013 - 06:17 PM
That's the way to do it use what you got.
Good Stuff :thumbs:
  • IamSherwood said thank you
#3 Username OFFLINE
Username
  • 2090 Thanks
  • 1435 posts
Posted December 01, 2013 - 07:20 PM
Plus you always have a tow chain handy should you get hung up.
#4 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted December 02, 2013 - 04:02 AM
Boy,i'd hate to see the dog at the end of that chain!! :D
  • Alc, IamSherwood and Sawdust have said thanks
#5 Alc OFFLINE
  • 8982 Thanks
  • 8293 posts
Posted December 02, 2013 - 06:28 AM
I read the post and thought  " 350lb of chain " , must be a type , then opened the pic for a beter look see !!!!  That's some chain !!
#6 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted December 02, 2013 - 06:38 AM
When you said something about big chain for weight... That's not what I expected.
Holy mackerel, that's big chain.
Does Wendy know you stole that out of her landscaping?
#7 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted December 02, 2013 - 06:43 AM
Which ship had its anchor cut loose? Eric Sent from my SPH-D700 using Tapatalk
Edited by dropped82, December 02, 2013 - 10:57 AM.
  • IamSherwood and Sawdust have said thanks
#8 Texas Deere and Horse OFFLINE
  • 15109 Thanks
  • 15570 posts
Posted December 02, 2013 - 07:00 AM
Will, That's some chain, did it fix the steering issue? The more weight you can hang behind the rear axle, the more the front will get lighter.and it will all help with traction. Good luck! :thumbs: :thumbs:
#9 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 02, 2013 - 07:32 AM
Those links are about 7" long. I have a buddy that works for CDN Coast guard.
They have a division that looks after the Buoys. That's anchor chain from a large
one. It gets replaced on a regular schedule, and usually goes for scrap.
Some how, 4 - 45 gallon drums of various sizes ended up in my storage yard. :smilewink:
I used about 16ft of 12" link chain, and welded them together, to make 2  roof support
posts at the entrance to a building. The 12" was from a ship. Looks cool.
Brian, yes it solved the steering issue.
  • MH81, Texas Deere and Horse and Cvans have said thanks
#10 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted December 02, 2013 - 09:51 PM
I had a necklace like one of those back in 1989. Seems I was bit 'off' from what was trendy.
walk this way, talk this way, walk this way, talk this way
just gimme a kiss!
#11 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted December 11, 2013 - 07:29 PM
Okay Will, you've solved the steering problem with the blower in transport position. How are you going to steer it with the blower on the ground? :wallbanging:
The tiller on my longer 1655 weighs 320 lb and steering was iffy on dirt in the summer without some weight (150 lb) on the front. On hardpack, yours is going to be nonexistant.
Lose about half of that chain! :thumbs:
#12 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 11, 2013 - 08:04 PM
Hi Bob.
It's been a while. I hope all is well.
I knew when I hung all that weight on the back, there could be a trade off.
As it turns out, I spent about 2 hours snow blowing with it today, and
it wasn't as self guided as I thought it might be. I was actually surprised
how well it did over the terrain I took it. If I get derailed too often, I can always
flip one of the 3 pieces off.
#13 Jacksdad OFFLINE
Jacksdad
  • 18 Thanks
  • 39 posts
Posted January 08, 2014 - 08:22 AM
That is a great Idea, Will. I don't have a blower(yet) for my 12, just a dozer blade. I have been looking for rear weight ideas to try. I actually have a chain similar to that. Not as long, but close in size. It weighs about 150 -175 lbs.
