Et3
146 replies to this topic
#76 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted July 16, 2014 - 09:16 PM
Could you get on under the seat? Or make a box to hold one on top of another in the very front?
  • DH1 and IamSherwood have said thanks
#77 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 16, 2014 - 09:29 PM
I have an idea. The 4th battery is the easiest. It is a pulling tractor so make a weight box up front and fill it with lead.
  • DH1 said thank you
#78 IamSherwood OFFLINE
  • 8,391 Thanks
Posted July 17, 2014 - 05:41 AM
Are there any other battery options you could look at?
They make some odd sizes for forklifts.
#79 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,725 Thanks
  • 2,160 posts
Posted July 17, 2014 - 06:03 AM
It would involve a lot more work but had you considered extending the frame and hood?
Good luck on finding a viable solution.  Looking forward to the end result.    Rick
#80 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 17, 2014 - 08:31 AM
When I was measuring mine, I was considering the T 105 or T125 6 volt battery to save on space. The motor mount I planned on dropping down a bit to free up some more space. Another consideration was under the seat, as Scott mentioned. However, unless you widen it and raise the seat, with those terminals, you run the risk of it arcing.
#81 Texas Deere and Horse OFFLINE
  • 14,815 Thanks
  • 15,502 posts
Posted July 17, 2014 - 08:52 AM
Doug, Do you have room to stack them 2 on 2 on a shelf?
#82 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted July 17, 2014 - 10:06 AM
Either a bracket off the front, or maybe there's room above the sleeve hitch mounts??  Up front you could make a cover to where it would almost look like a ballast box.
#83 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 17, 2014 - 10:16 AM
I would make the original battery box longer and add one there, then the other three 6 Vs. Or do that with the 12v. But, now you have the hood making contact with the battery terminals if you don't drop it down enough.
#84 MH81 OFFLINE
Posted July 17, 2014 - 11:28 AM
Do they make a side post version?
#85 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 17, 2014 - 12:01 PM
interstate does, but their garbage IMO. I've had nothing but bad luck with them.
Thinking outside the box,
http://www.trojanbat...roduct/ind9-6v/
That battery may help with it's thin width, height may be an issue though.
#86 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted July 17, 2014 - 06:42 PM
I original thought of putting 1 battery under the seat but when I first looked at it I thought there wasn't enough space, I think I should take a closer look.
Putting a battery out front, I never even thought of doing that, there is lots of room there for 1 battery.
Putting 2 batteries under the hood, 1 out front and 1 under the seat or out back would solve the problem.
#87 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted July 17, 2014 - 06:51 PM
This is what I have binging trying to do, vertical space is tight.
Figured to put 1 battery low in between the frame rails and clear the steering arm, with 3 above.
To do this I need to move the motor rearward, modify the frame, cut out the gas engine mounting plate, widen the top dash supports and the battery terminals would have about 1" clearance from the hood.
Maybe this would work ???
#88 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted July 17, 2014 - 07:00 PM
I never even thought of mounting 1 battery out back above the sleeve hitch and rear PTO shaft.
How much clearance around the PTO do you need on a D4-10?
#89 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted July 17, 2014 - 07:02 PM
I really don't want to do that unless I have to BUT that would solve the problem.
#90 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted July 17, 2014 - 07:03 PM
Oh, I forgot you want to be able to use the rear pto.  I think the pto might make things too tight for a battery back there.  But then I've never looked at that area for such an application.
