Et3
147 replies to this topic
#31 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 11, 2014 - 04:22 PM
This should prove interesting! Go, Doug, Go!!!!!!  Gonna plow with it at Daniels this fall?
  • DH1 said thank you
#32 IamSherwood OFFLINE
  • 8,395 Thanks
Posted May 11, 2014 - 05:01 PM
Didn't take you long to tear into that Doug.
You should be able to squeeze those batteries in there.
Looking forward to the progress updates.
#33 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted May 11, 2014 - 05:03 PM
That's the idea see if I can get it to work, I don't think it's going to plow for to long though.
#34 olcowhand ONLINE
  • 43,162 Thanks
  • 32,011 posts
Posted May 11, 2014 - 05:08 PM
I think with the motor kicked back closer to the dash that you could get the 4 batteries in there with relative ease.   But then I've never laid a battery sideways in these frames either.
  • DH1 and KennyP have said thanks
#35 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted May 11, 2014 - 05:41 PM
6 6 volts could work, measuring, the 12V would eat up a lot of space on that compact frame.
#36 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted May 11, 2014 - 05:43 PM
I need a 48 volt battery pack, could use 6 - 8volts batteries maybe. ???
#37 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,219 Thanks
  • 2,271 posts
Posted May 11, 2014 - 05:48 PM
Looking forward to how this turns out. :thumbs:   Rick
#38 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted May 11, 2014 - 07:45 PM
I'm golf car based, so I mostly see 36v systems.
#39 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted May 11, 2014 - 07:52 PM
You use the 1275 Trojan batteries at all?
#40 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted May 12, 2014 - 11:34 AM
Sure do, they are pretty popular. Need measurements?
#41 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted May 12, 2014 - 07:37 PM
Yes and thanks
#42 TX_Dj OFFLINE
TX_Dj
  • 141 Thanks
  • 84 posts
Posted May 16, 2014 - 11:37 AM
8 Volts are a good compromise if you can't get enough 6's in there, and need more energy density than 12's can provide.
There are, of course, other options available as well.  I've built things before with smaller "bricks" of 12v in multiple strings to provide the energy density required.  One such example is my old(er) racing scooter, which led me to win the scooter challenge in my local ev club a couple times.  I was in the 36v class, I wanted power for acceleration, as well as top speed, and also needed long range since the event was a combination of drag race, timed speed between a pair of traps, and maximum endurance.
That's two strings of powersonic high discharge rate SLA 12v bricks.
  • DH1, Texas Deere and Horse and sacsr have said thanks
#43 Texas Deere and Horse OFFLINE
  • 14,900 Thanks
  • 15,518 posts
Posted May 16, 2014 - 12:35 PM
How do you charge the 8vt battery's, just charge them in series with a 48vt charger?
#44 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted May 16, 2014 - 01:15 PM
for 48 volt, you need either 6- 8volts or 8- 6volt batteries.
Find yourself a used Ezgo or club car 48V charger. Typically those are for sale for $100-$150. Get an SA-8 Anderson plug for both the GT and the charger, will make life easier.
#45 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted May 16, 2014 - 01:16 PM
http://beavergolfcar...ngDiagrams.aspx
For golf car wiring diagrams.
