For Sale
Kohler Engine Parts
50 replies to this topic
#1 rrmeidl OFFLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted December 01, 2013 - 12:48 PM
Hello, I'm no longer working on engines so the wife told me to clear out the shop. Attached is a list of parts I have left over. Buyer must make sure part # is correct for your application. I have no prices listed so PM me with what you need and I'll shoot you a price. The more you buy the better deal you get. All parts are NOS with most in original boxes. Have a nice day!
RickAttached File  Kohler Parts list.PDF   418.42KB   270 downloads
  • KennyP, drbish, Littledeere and 5 others have said thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 01, 2013 - 01:11 PM
Rick does have some good pieces at very good prices, its worth your time to look.
Ben W.
  • KennyP and rrmeidl have said thanks
#3 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted December 05, 2013 - 09:47 AM
Rick, I am not familiar with the part numbers to know if you have a starter for a M18. But if you have a good one I might be interested.
#4 rrmeidl OFFLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted December 07, 2013 - 12:57 AM
Sorry but no. you need a 52-098-12. don't have one.
#5 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted December 15, 2013 - 12:33 AM
crank for a K 181, 3/4" PTO, NOT tapered   I have a tapered POS  crank in an engine under the bench  good low usage engine otherwise, but tapered crank makes it unusable to me. need 3/4" as I plan on this engine going onto a troy bilt horse.    sorry I don't have a model number tag on the engine
also starter cup for a recoil start equipped M12, That one I can get you a number if needed.
gov linkage that mounts on the engine shroud of an M 12 (think I can get you a number from that engine too if need be, different engine than  need the starter cup for)
Would you have any of this?
Edited by dodge trucker, December 15, 2013 - 12:34 AM.
#6 rrmeidl OFFLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted December 15, 2013 - 03:38 PM
I have the K181 crank with the 3/4" PTO. $75 plus $15 shipping. Check out partstree.com they want $488, that's nuts. The rest I don't have sorry. I also have a new cam, valves with springs and tappets, piston and the gasket set if you want to do a complete rebuild on it.
Edited by rrmeidl, December 16, 2013 - 01:52 PM.
#7 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted December 15, 2013 - 10:30 PM
I need a starter for a K341. Sorry I dont know the part number.
#8 rrmeidl OFFLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted December 16, 2013 - 11:08 AM
Sorry I don't have one. You need a 45-098-10s
  • coldone said thank you
#9 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,420 Thanks
  • 1,855 posts
Posted December 17, 2013 - 12:27 PM
What would a whole rebuild for a k181 like previously mentioned cost? Valves springs tappets piston gasket set
DO NOT NEED CAM but everything else
Edited by Tommy Williamson, December 17, 2013 - 12:28 PM.
#10 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted December 17, 2013 - 09:15 PM
 I have a new piston, rings and gaskets here already if I can find it...  this engine did way more sitting than anything still shows cross hatch, and Std piston too.   probably stick a crank in it and new gaskets w/o pulling the piston or rod out of the cylinder in this case
#11 jimbobbillyray ONLINE
jimbobbillyray
  • 2,787 Thanks
  • 2,755 posts
Posted December 18, 2013 - 05:39 AM
do you have a carb. for a 14 hp motor on a john deere 140?
#12 rrmeidl OFFLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted December 18, 2013 - 11:35 AM
I could let you have it all for $300 plus $20 shipping. The one item I do not have is the rod.
#13 rrmeidl OFFLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted December 18, 2013 - 11:36 AM
It would help if you could give me the spec # on the engine.
#14 VintageIronCollector OFFLINE
  • 1,420 Thanks
  • 1,855 posts
Posted December 18, 2013 - 06:33 PM
For k181 gasket set only cost?
#15 rrmeidl OFFLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted December 19, 2013 - 11:13 AM
You can get it on E-Bay for $23
