Help Me Make A Decision.
18 replies to this topic
#16 Cvans ONLINE
  • 7,305 Thanks
  • 6,389 posts
Posted November 30, 2013 - 11:23 PM
There was a hydraulic lift available for the G6200 and possibly the G5200. Check the parts brake down and see where the ports on the hydro were located and check that against yours. I happen to be a big fan of these tractors so I the Kubota would stay if it were mine.
#17 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted December 01, 2013 - 03:27 PM
I will have to pull the fender pan off the kubota to get a good look at the hydro, I dont believe it is ported though. My hope was to get the hydraulic pump that is driven off the back of the fuel pump, I will have to make an effort to find one. I was told on this site that it is a special pump because it turns half engine speed, I will probably just get a p/s pump from an automotive application and belt drive it, seems the simplest way to go. I do have a soft spot for the kubota because it was my first real garden tractor and still has less than 900 hrs on it according to the meter. Like every one I have seen it has the crinkled front of the hood but is in pretty good shape otherwise.
#18 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted December 01, 2013 - 03:30 PM
Oh I almost forgot, I believe it has an eaton 11 hydro, I'm not having much luck finding a parts breakdown or a good pic of a ported version, any help would be much appreciated.     Bill.
#19 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted December 01, 2013 - 03:41 PM
You might check out the Bolens HT23 It has an Eaton 11.
