Picking Up Another Piece (Or Two) To The Bh Puzzle Tomorrow
137 replies to this topic
#121 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted January 06, 2014 - 09:09 AM
2 of my JB's came with the Terra ags when I got them, and going by the dry cracks, I'd say they are original for sure.  I still have one set taken off, and my JBI in original trim still has it's original Terra ags on it.
  And of course I don't mind you reusing that pic.  Do so with any of my pics when you need/want.  :thumbs:
  • Texas Deere and Horse and sacsr have said thanks
#122 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted January 06, 2014 - 09:33 PM
I was trying to remember if any other tire co. even made a 12X12- 26 Ag tire back then.
#123 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,361 posts
Posted January 12, 2014 - 05:26 PM
#124 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted January 12, 2014 - 07:07 PM
Oh man!  I gotta tug on my friend's arm at Bush Hog!
  • sacsr said thank you
#125 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted January 12, 2014 - 07:54 PM
Nice! Been looking for one :) Enjoy it!
#126 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,361 posts
Posted January 30, 2014 - 06:51 PM
Finally got some seat time on the JB. I think the points were set too close. It was set that way when I bought it, but I have had starting issues from day one. I went through last night, reset the carb, re-set the points and when I hit the key today, it turned over faster than it ever had. Would setting the points correctly have done that??Anyway she started well, ran pretty good, I am going to do a video this week it.....it runs a while.....then sputters/hunts....the runs a while...then sputters/hunts.
Put on the brinly blade and moved some snow off my drive way. I learned a lot tonight about using a blade and why your want to use the float :D ....may have been obvious to y'all but I am still a newbie learning/stumbling as I go. :thumbs:
  • olcowhand, MH81, HowardsMF155 and 1 other said thanks
#127 MH81 OFFLINE
Posted January 30, 2014 - 08:06 PM
The advantage to not using float is the extra seat time come spring to put the gravel back.
  • KennyP and sacsr have said thanks
#128 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted January 30, 2014 - 08:16 PM
If the points are set too close, the timing will be advanced making harder to spin over starting because they already firing before top dead center TDC. when set right.
  • sacsr and trowel have said thanks
#129 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 30, 2014 - 08:18 PM
:ditto:  .020 on the points.
#130 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted January 31, 2014 - 08:45 AM
I believe that the wider the points gap, the more advanced the timing.  Most of my Kohler's I've owned were between .018 and .019" when set with a timing light for accuracy, but I can't remember on the Briggs.
#131 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,361 posts
Posted January 31, 2014 - 06:16 PM
Setting on thus motor is .020. Ever since adjusting the points, the motor turns over faster and it starts every time. Glad I got that fixed!
#132 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,361 posts
Posted January 29, 2015 - 06:30 PM
Went back out again.  Could just barely see the numbers on my OE JBI's engine, but they are 320424-0127-01-6908111  It's tractor serial number is 554.  I figured it to likely be a 69 model.  It doesn't have the hood cutout.
WAIT, I just noticed the Hogzilla's serial number is 694, so the cutout is for a later tractor than my original condition JBI.  That or it was an awfully perfect cutout made by an owner.  I bet Hogzilla is a 70 model!  Kinda makes more sense they may have added the cutout on later series.  If you notice Scott, your hood is nearly or is touching the filter top.  Maybe they started cutting them out later??   Heck, all this time I thought the Hogzilla JBI was the oldest!  I haven't paid attention to the serial numbers in a long time.
I just checked the motor number on the new to me JB1 with the fel mounts. Exact same numbers as yours Daniel! 320424-0127-01-6908111  - so made on the same day?? Was yours red in color?? Serial number on this one is 521. So it is earlier than the one in this thread. As of now the 521 is the earliest confirmed still out there JB.....
  • KennyP and Rock farmer have said thanks
#133 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted January 29, 2015 - 06:36 PM
They must have been built the same day then!  Yes, mine is red, original paint.
#134 KennyP ONLINE
  • 37,397 Thanks
  • 45,448 posts
Posted January 29, 2015 - 06:41 PM
So you guys have twins separated at birth, then!
  • olcowhand and sacsr have said thanks
#135 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted January 29, 2015 - 06:42 PM
I reckon so, but if Scott can bring it to the plow day this fall, it will truly be a reunion!  :thumbs:
  • Texas Deere and Horse, KennyP and sacsr have said thanks
