Sears dozer blade
4 replies to this topic
#1 cubmod72 OFFLINE
cubmod72
  • 2 posts
Posted December 19, 2010 - 05:57 PM
Hey all, Im going to be helping my buddy hook up a dozer blade on his sears suburban. I was wondering if anyone had some close up pictures that would help me? Thanks in advance
#2 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted December 19, 2010 - 06:08 PM
Welcome to the Forum!
There are some knowledgeable sears guys here that should be able to lend you a hand.
#3 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted December 19, 2010 - 07:01 PM
No pics, but its a striaght forward process
1: Slide the mount into the area where the mule drive went. There should be a hinged dust cover over it just above the front axle and below the grill
2: Attach the "frame hooks". These should be on the lower side of the blade mount that you just pushed into the mule drive slot. Mine has two, a simple bar that looks like one of these [ , one end is attached to the blade mount and the other slides into the weldments on the axle. The other one is forked at the end and attches to the weldments on the other side front axle.
Mine does not have the mounting hardware for the adjusting levers that attach to the side of the tractor.
Hope it helps.
#4 mjodrey OFFLINE
Posted December 20, 2010 - 04:23 PM
cubmod72:welcometogttalk:
I can't help you,but someone will be along.
#5 cubmod72 OFFLINE
cubmod72
  • 2 posts
Posted December 20, 2010 - 06:27 PM
Thanks alot guys, These sears are new to me so the info really helps. Thanks again
