Ford Yt18H, Kohler Engine, Need Gas Cap
26 replies to this topic
#1 retrofitter OFFLINE
retrofitter
  • 12 Thanks
  • 15 posts
Posted November 29, 2013 - 07:36 PM
New member looking for information on Ford YT18H.
I just purchased this lawn tractor to use as a backup and project to work on/ renew.  Need to do some sandblasting on the deck and replace some bearings and idler pulleys.  The best I can determine tractor was made by Gilson.  I have the original Ford manuals for the 48" mower and tractor.  Mower manual has a parts diagram/parts list but no part no's.
Right now I need a gas cap, old one is in bad shape and cracked.
Can anyone help with a part number or know of one that will fit it.
All information will be appreciated.
Thanks,
Tom
  • Dieselcubmike said thank you
#2 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted November 29, 2013 - 07:45 PM
Welcome to the forum, one of the Ford guys will be along to help I'm sure, and remember we love pictures!!
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted November 29, 2013 - 08:00 PM
Complete fuel tank on Ebay, no gas caps available that I saw.
http://www.ebay.com/...=item4d14d0a2e5
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted November 29, 2013 - 09:02 PM
If someone sends me some measurements of what it should be, I can probably get you a replacement.
Ben W.
  • retrofitter said thank you
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted November 30, 2013 - 12:01 AM
Hello and welcome :wave:
#6 KennyP ONLINE
  • 40,054 Thanks
  • 46,736 posts
Posted November 30, 2013 - 07:27 AM
The gas cap part # is LB740378. New Holland is rather proud of them as they want $95 for it. Not sure how to cross it over.
Here's a mower manual with part #'s for the 63687A &63688C decks.
Attached File  YT 42 and 48 inch Mower Attachment Manual.pdf   1.79MB   88 downloads
  • Cat385B and retrofitter have said thanks
#7 retrofitter OFFLINE
retrofitter
  • 12 Thanks
  • 15 posts
Posted November 30, 2013 - 09:19 AM
Thanks guys for the replies.  I saw the complete tank on ebay.  Is that the original type cap?  Mine is a gauge type with float on the cap about 6 " long and the cap measures 2.25" inside dia. on the edge before the threads. Someone has put rtv on the outside of the cap, where the indicator would be, because of leaks and the cap is split.
#8 KennyP ONLINE
  • 40,054 Thanks
  • 46,736 posts
Posted November 30, 2013 - 09:41 AM
With those dimensions, someone can surely cross it for you.
#9 retrofitter OFFLINE
retrofitter
  • 12 Thanks
  • 15 posts
Posted December 01, 2013 - 08:30 AM
I have found several on the internet but I'm not sure how they are measured as far as inside dia.. Do you measure inside the threads or inside the lip? There is at least 1/8" difference.  It's hard to get an exact reading since the cap is split thru the treads and spread a little.  I  may just use a cap with gauge if I can find the actual size.  I have found replacement but $96 is rediculous.
#10 KennyP ONLINE
  • 40,054 Thanks
  • 46,736 posts
Posted December 01, 2013 - 08:45 AM
New Holland is going to have lots of inventory at those prices, for sure!
#11 retrofitter OFFLINE
retrofitter
  • 12 Thanks
  • 15 posts
Posted December 14, 2013 - 03:30 PM
PM sent to superaben
#12 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted December 15, 2013 - 08:49 AM
For future reference, Ford YT18H can use a fuel gauge I can sell for $22.10, 1/2 inch short at 5 inches.  Length of gauge should be 5 1/2.
Ben W.
#13 KennyP ONLINE
  • 40,054 Thanks
  • 46,736 posts
Posted December 15, 2013 - 09:24 AM
Ben W.
What threads does it have? Standard GT fuel tank? I have a need in the future!
  • superaben said thank you
#14 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted December 15, 2013 - 04:20 PM
2 1/4, I think it was 5 threads per inch.  As long as you have a plastic tank, it will work.  Steel tanks can use a different thread.
Ben W.
#15 KennyP ONLINE
  • 40,054 Thanks
  • 46,736 posts
Posted December 15, 2013 - 04:38 PM
Should work for what I have in mind. Thanks, Ben!
