Case 224 Wiring Diagram?
7 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted November 29, 2013 - 01:44 PM
I checked, maybe I missed it. My wiring is shot and it's gutted. Wasn't much to begin with anyway. My Volt reg is rusted to all heck and getting replaced.
Anyone happen to have the wiring diagram handy? Thanks guys!
#2 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted November 29, 2013 - 04:47 PM
http://gardentractor...22-224-and-444/
see page 17
  • Titus and bowtiebutler956 have said thanks
#3 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted November 30, 2013 - 09:04 PM
Darn, that's not the one. Mine has a starter generator
#4 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted November 30, 2013 - 09:44 PM
Go here and look up parts manual for your tractor it will have wire diagram in it  http://www.eastmanind.com
#5 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted December 01, 2013 - 01:54 PM
Thank you for the link!
http://eastmanind.co...50fU=&tabid=196
This one matches mine.
#6 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted December 07, 2013 - 10:03 AM
Got everything rewired last night. I'm able to turn it over with the key switch now. Problem I'm having is still no spark.
I noticed that the headlights also don't work. The ground is wired into the coil. I'm wondering if the coil could be bad.
  • bowtiebutler956 said thank you
#7 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted December 07, 2013 - 10:47 AM
 Just to make sure. The only ground wire the coil should have going to it, is the one coming from the points, and going to the negative side of the coil. It should not have a chassis or battery ground going to it. If it does, it cannot charge the coil.
Matt
#8 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted December 07, 2013 - 11:11 AM
I found the following wiring diagram for Kohler battery ignition.
(http://www.ihcubcadet.com/forum/messages/106/59180.html?1181594442)
The ground goes through the points and the condenser is in parallel with the points.
Maybe someone knows the expected resistances for the primary and secondary circuits in the coil.
