Mf8Executive Resto And Upgrade.
207 replies to this topic
#121 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 12, 2014 - 07:49 AM
Haven't had much time for this lately, as mother nature has been
keeping me busy. I'm also waiting for Canada Post to bring me the
inline hydraulic filter.
Yesterday, I got around to dealing with an issue I'd overlooked right
from the start. The driven pulley on the tranny, was not original, and
someone had done a poor job on installing it, hence it became
loose and wore out the bore to .030" over 5/8". It couldn't be left that
way, so I found a new cast pulley. Problem is that the input shaft
of the tranny was made for a 5/32" x 5/8" woodruff key, way back then.
Current standard for a 5/8" shaft, is 3/16" key. Rather than trying to single
point cut a 5/32" keyway in the new pulley, I hand filed a step key.
I lucked out, and found some pieces that helped me then fit the pump
drive pulley to the new tranny driven pulley.
I my box of goodies I had a 5/8" shaft stub, a 5/8" ID x 7/8" OD bushing, and
a 7/8" ID weld in hub that fit nice and snug into the pump drive pulley.
This way I could bolt together the pulleys with stand off spacers, nice and true.
  • olcowhand, MH81, Texas Deere and Horse and 3 others have said thanks
#122 Walkinman1 OFFLINE
Walkinman1
  • 773 Thanks
  • 599 posts
Posted January 12, 2014 - 08:21 AM
I admire your patience, hand filing a key like that is not easy (at least not for me) and it's a very tedious process!
  • IamSherwood said thank you
#123 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 12, 2014 - 08:54 AM
Thanks. :smilewink: My German tool and die maker father taught me that, while I was born and
raised in his custom machine shop.
I'll never forget him telling me how he learned to file while he apprenticed. They had to
take a 25mm (1") round bar, file it square, to fit perfectly into a square hole they had
filed into a 25mm thick flat bar. They spent a couple of hours a day over a semester
doing that. Talk about patience.
BTW, I only filed the step in the key. I'm not that patient. At one point, I looked at my
welder. :D Nah.
#124 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted January 12, 2014 - 10:02 AM
So, the step is exactly the same on both sides? Any off will mess with timing...
Kinda Like I'm messing with you now.
Looks good Will. Wow you've got steady hands.
  • Texas Deere and Horse and IamSherwood have said thanks
#125 KennyP OFFLINE
  • 50948 Thanks
  • 52627 posts
Posted January 12, 2014 - 10:53 AM
Now we all know who to send these parts to for filing! :smilewink: :worshippy1:
#126 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 12, 2014 - 12:50 PM
As I started to drop and shake my head from right to left, I found the second line. :thumbs:
#127 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 15, 2014 - 08:16 PM
:dancingbanana: Yippy, it works.
The hydraulic filter finally showed up, so I reassembled all the painted
parts, and gave the hydraulics a test run.
http://www.youtube.c...h?v=nCz0iqWUBYQ
I then went and got a 10" plow, just to be certain. No problem, other than the
lever stopped returning to neutral. (you can see how I have to tap the lever back)
 I thought, OH Great, the weight of the
plow is flexing the frame, and causing the lever to bind in it's shaft collar
bearings.
http://youtu.be/pfUvrUx-AIQ
So, I took the plow off. Same thing. That's when I decided to grease those shaft collars
that I put grease fittings in to. Duh. All is good again. Purely happenstance.
I'm real happy with how it works. Moves at a good speed. At the end of the cyl stroke
it doesn't over labour the engine.
  • olcowhand, DH1, MH81 and 7 others have said thanks
#128 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted January 15, 2014 - 08:21 PM
Good Stuff it works :thumbs: :thumbs: :thumbs:
#129 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Looks great.
#130 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 16, 2014 - 08:05 AM
I also got around to modifying a tunnel tin bracket, to mount the brake light switch
on. The spring on the switch is hooked to a little block I made, that's set screwed
to the brake linkage rod.
Today I'll wire that, and do a bunch of touch up paint, and then It'll be time
to put the wheels on.
Also, here is a pic of the neat little inline filter I got from Mcmaster Carr.(below gas
tank)
  • olcowhand, MH81, Texas Deere and Horse and 5 others have said thanks
#131 KennyP OFFLINE
  • 50948 Thanks
  • 52627 posts
Posted January 16, 2014 - 08:32 AM
That's great, Will! Now to get the tractor together and wait for the ground to THAW! :tapping_fingers:
#132 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 16, 2014 - 08:43 AM
Don't be tapping your fingers too much there Kenny. You'll end up with blisters on the tips. I
was just looking at the long range forecast. It's going to be a while before plowing season.
Maybe I shud quickly rig up a snow blade for this one. I've got a blade and hydraulics for
the lift. It wouldn't take all that much to fab up a mount, and lift linkage. Hmmmmm!
I know where the blade is too. It's over in that general area, under 3 ft of snow. hmmm....
#133 KennyP OFFLINE
  • 50948 Thanks
  • 52627 posts
Posted January 16, 2014 - 09:02 AM
Just load it up and bring it down here! Ground is thawed. We'll find something we can test it out on.
#134 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 16, 2014 - 09:10 AM
As usual Will, super clean work!  I don't take the time to do such nice detailed work like you do. I appreciate the effort it takes.
#135 Texas Deere and Horse OFFLINE
  • 15111 Thanks
  • 15570 posts
Posted January 16, 2014 - 01:08 PM
Working GREAT Will, very nice and neat job. Looks like a factory option!
