Mf8Executive Resto And Upgrade.
207 replies to this topic
#106 Gav694 OFFLINE
Gav694
  • 267 Thanks
  • 184 posts
Posted December 31, 2013 - 04:08 AM
I'm not sure what you mean here?
Rather than adding a flow restrictor into your set-up change an existing fitting somewhere between the valve block and Ram for one with only a tiny bore, or make an insert to press fit/weld inside a fitting that partially blocks the flow of oil.
  • IamSherwood said thank you
#107 Alc OFFLINE
  • 8983 Thanks
  • 8293 posts
Posted December 31, 2013 - 06:48 AM
Missed your build until today , WOW you get a lot done ( great work too )  in short amount of time :worshippy1:  :worshippy1:
#108 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 31, 2013 - 07:54 AM
Ok, thanks for the explanation. It wouldn't be readily accessible, but I
think I can squeeze one (as above) in on the rod end of the cylinder.
That hose could just loop further forward, without causing any other
issues. I'll try it first, and then decide.
  • UncleWillie said thank you
#109 twostep OFFLINE
twostep
    Rockstar
  • 1994 Thanks
  • 2541 posts
Posted December 31, 2013 - 08:51 AM
What they are referring to is a hydraulic flow restrictor orifice.
http://www.tractorby...or-orifice.html
Again, not adjustable but small and inline. Plus if you don't like the speed you can change to a different size.
#110 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 31, 2013 - 02:33 PM
Thanks for that link. I called the hydraulic shop in town, to see if he had a 1/4" adjustable flow
control. Nope. I just wanted dimensions at this point. He explained to me, how he's done
basically the same thing as the guys on TBN talk about. Well, I've got options now.
#111 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 02, 2014 - 10:09 PM
I'm thinking I might like to add a brake light to this one.
Any ideas/suggestions on how I could go about that?
#112 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted January 02, 2014 - 10:51 PM
Yes, this should work.
http://www.ebay.com/...S-/291003742295
  • IamSherwood and KennyP have said thanks
#113 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 02, 2014 - 11:00 PM
Oh, look at that. That'll do it, but it just seems so simple of a solution.
I could easily have amused myself for a full day, doing it with the crazy idea
I had upstairs.
Thanks Alan.
  • MH81, KennyP, twostep and 1 other said thanks
#114 KennyP OFFLINE
  • 50116 Thanks
  • 52292 posts
Posted January 03, 2014 - 07:44 AM
I had upstairs.
Thanks Alan.
Is this to let that "tailgating" moose know your stopping? If it's a bull moose, he may just plow into to you.
#115 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 03, 2014 - 07:57 AM
I plan on bringing this Exec to plow days. After going to that one in Pa. in mid Nov. and
seeing Alan drive, I thought a brake light might be a good idea. :D
#116 KennyP OFFLINE
  • 50116 Thanks
  • 52292 posts
Posted January 03, 2014 - 08:24 AM
Now I understand! Might want turn signals too! Warning flashers?
#117 Texas Deere and Horse OFFLINE
  • 15109 Thanks
  • 15570 posts
Posted January 03, 2014 - 12:21 PM
:bigrofl: :bigrofl: :bigrofl: :bigrofl:
#118 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted January 06, 2014 - 09:15 PM
I think that having a brake lite for the Sears and a horn for the John Deeres would be a good idea. :rolling:
  • Texas Deere and Horse, IamSherwood and KennyP have said thanks
#119 Texas Deere and Horse OFFLINE
  • 15109 Thanks
  • 15570 posts
Posted January 06, 2014 - 09:19 PM
I have an extra cigarette lighter from a WH, I can bring up too!! :rolling:
#120 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 07, 2014 - 12:25 PM
Good come back Alan. I was also thinking about adding a windshield
washer pump kit, aimed out back, just in case you doze off. Isn't there
a pic out there to that effect. :smilewink:  One just never  knows, so be prepared, is best policy.
  • MH81, Texas Deere and Horse, KennyP and 2 others have said thanks
