Mf8Executive Resto And Upgrade.
207 replies to this topic
#76 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 22, 2013 - 06:44 AM
I can see Will, obliviously driving around, his plow going up and down and making a stitch pattern in his wife's nice front lawn... :rolling:
.....staring at the sky, wondering why it's blue, and watch clouds form that look like big fluffy tractors. :rolling:
  • MH81, KennyP, twostep and 1 other said thanks
#77 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 22, 2013 - 06:50 AM
Christmas stuff got in the way, but I had time to stop over thinking the spring thing.
Works good. I can drop out a chain link if it needs more tension. Also got that
anti belt slop idler mounted.
Also got the hoses measured up and ordered.
  • olcowhand, MH81, wvbuzzmaster and 3 others have said thanks
#78 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted December 22, 2013 - 06:55 AM
Looks good to me, Will! Nice to have adjustment for the spring tension!
  • IamSherwood said thank you
#79 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
You're going to be up and running next weekend! Way to go, Will. Top notch work.
#80 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 22, 2013 - 07:09 AM
Thanks.
Yes, should be, if I can get my brother to his lathe, and spin up the pump pulley extension.
That may take 1/2 a bottle of eggnog, so....., I see a delay coming there.
I'll test it all, then tear it apart for paint.
  • JDBrian and twostep have said thanks
#81 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted December 22, 2013 - 07:24 AM
Geez, even on the days you get nothing done, you get more done than me.
Looks good Will.
  • IamSherwood and twostep have said thanks
#82 Walkinman1 OFFLINE
Walkinman1
  • 773 Thanks
  • 599 posts
Posted December 22, 2013 - 07:33 AM
No kidding, he's making the rest of us look bad...someone go slow him down lol, just kidding Will, it looks great so far!
#83 KennyP ONLINE
  • 50026 Thanks
  • 52252 posts
Posted December 22, 2013 - 07:38 AM
You all forget that he has that nice warm Massey Hall extension done, so has room to work. I'm shut down right now unless I set up a fire barrel! May have lots of wood to burn though!
  • IamSherwood, JDBrian and twostep have said thanks
#84 Walkinman1 OFFLINE
Walkinman1
  • 773 Thanks
  • 599 posts
Posted December 22, 2013 - 07:40 AM
I have a nice warm shop to work in too, just no time or money for parts :(
#85 JDBrian OFFLINE
  • 9666 Thanks
  • 14162 posts
Posted December 22, 2013 - 07:58 AM
Will, that's looking great. Thanks for sharing the build. it's interesting to see you work through the problems. Nice fabrication work !
#86 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 22, 2013 - 07:07 PM
Got to fix the brake linkage issue I created by adding the hydraulics.
Here is what I faced. 1st pic=clutch in drive.
                                  2nd pic=clutched.
That fitting was in the way, so I made up a new linkage.
I ended up with some interference on the lift strap, and rod end clevis
pin at the brake band end, so I tweaked the lift strap too. While I was at
that, I slotted the joint in the lift strap, to allow for some adjustment.
#87 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted December 22, 2013 - 07:30 PM
Looks good Will. You still need the parking brake lever don't you? Will it interfere too now?
#88 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted December 22, 2013 - 07:33 PM
Just spent the last ten minutes going over the thread with Ryan.  We are both  :worshippy1:  :worshippy1: of your problem solving abilities.
#89 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 22, 2013 - 07:47 PM
Thanks Casey.
Yes, I still need that lever. It's for that 7E I picked up on plow day.
On the 7E the park brake lever is on the back.
On the 8E, the "conveniently" located parking brake is way down there,
out of reach on the foot rest.
  • MH81 and Gav694 have said thanks
#90 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 27, 2013 - 08:32 PM
It's been a while, since I did an update here. Between snow plowing, plowing,
Christmas, plowing, plowing, and plowing, I haven't had much time on this
project. Finally today, I got back at it, and finished up the last of the
fabrication.
Bracket in front of battery, with clamp to secure return hose.
Bracket below/behind check valve, to secure tin to.
Pump belt tensioner idler bracket, on right side of frame.
Pump belt and tensioner idler.
Flange fittings welded into tank.
And a picture of lots of fittings.
  • olcowhand, DH1, MH81 and 4 others have said thanks
