Mf8Executive Resto And Upgrade.
207 replies to this topic
#31 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 10214 Thanks
  • 5240 posts
Posted December 07, 2013 - 09:47 AM
Yesterday, I remembered, that I forgot to do something.
I am much better at forgetting to remember than I am at remembering what I forgot.  :(  :rolling:
  • IamSherwood said thank you
#32 Sawdust OFFLINE
Sawdust
  • 6794 Thanks
  • 3799 posts
Posted December 07, 2013 - 05:43 PM
Looking real good Will!
#33 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 13, 2013 - 12:31 AM
Had it running today, up on the operating table. Sounds nice
with the new muffler. There are a couple little things I need to
tweak. I need to put some belt guide fingers around the PTO
belt, so it doesn't flop around when clutch is depressed, and
put a baffle in the gas cap to stop gas from splashing out the
vent hole. It eats fresh paint.
I'm still waiting for the hydraulic stuff to show up, so not much
else to report. Sorry, no pictures as the camera is broken.
Picking up a new one tomorrow.
  • KennyP and sacsr have said thanks
#34 KennyP OFFLINE
  • 50116 Thanks
  • 52292 posts
Posted December 13, 2013 - 06:48 AM
Hopefully soon you can get it off that table and into recovery!
#35 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 13, 2013 - 07:45 AM
Yes, because they're lined up in the Hall waiting to be next. :smilewink:
#36 KennyP OFFLINE
  • 50116 Thanks
  • 52292 posts
Posted December 13, 2013 - 07:57 AM
AH! The good doctor has more patients in line! Better get those supplies ordered before they have to be delivered by dog sled!
#37 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 13, 2013 - 08:02 AM
To late for that Kenny. We're into winter here. Been snowing for the
past 4 days. As long as I keep the drive way clear, the UPS truck
can deliver more vital parts.
  • wvbuzzmaster, KennyP and sacsr have said thanks
#38 daytime dave OFFLINE
  • 5442 Thanks
  • 6772 posts
Posted December 13, 2013 - 08:43 AM
Great winter project Will.  Wonderful photographs.
#39 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 14, 2013 - 07:28 PM
Still waiting for hydraulic stuff, and it was too cold to
spend all day outside, so I decided to tackle the
hyd oil reservoir. I hope I'm not looking for trouble
with the location I choose, but I didn't really have any
options. My concerns are that the oil may get heated by the
exhaust, and I might be blocking a bit of the air flow over the
engine's head fins, created by the flywheel.
I'll most likely put a heat shield over the exhaust pipe yet.
Space between tank and head is about 3/4".
Inlet hole is behind tape. I'm waiting for the weld-on pipe thread
flanges.
Outlet hole. I'm going to brace horizontally from that 1/4" bolt on
the side of the head, to the tank yet.
Also, the gas tank standoffs.
  • MH81 and Sawdust have said thanks
#40 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted December 14, 2013 - 07:31 PM
Will, I too am concerned with that heat possibility being so close to the exhaust. Do not want that oil bubbling, then you risk cavitation of your hydraulic stuff
#41 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted December 14, 2013 - 07:47 PM
A heat shield and then a good fiberglass matting should keep most of the heat off it. BTW, a shiny shield will reflect more than just a regular piece of metal.
In between the tank and the reflector, try something like this
The music is over the top, but I've seen materials like this protect a fridge cabinet while mapp brazing with almost no paint discoloration.
  • wvbuzzmaster, IamSherwood, sacsr and 2 others have said thanks
#42 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted December 14, 2013 - 07:59 PM
That Hyd tank fits under the hood?
#43 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
I've got about 5/8" between the pipe and tank. I could weld four
1/4" nuts to the tank, and sandwich some material like that with
a piece of plated roof flashing material. For what it takes, I'm going to do that.
Just have to find some of that. I think I have some asbestos. That'd work too.
  • wvbuzzmaster said thank you
#44 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 14, 2013 - 08:02 PM
Yes, just. There is about 1/4"  of air space, at the back left corner.
#45 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted December 14, 2013 - 08:05 PM
Can you raise the tank up so that the bottom of the tank is the same level as the top of the engine?
This would give the airflow coming out of the engine a clear straight path out.
That would solve the heat problem as the airflow is high coming out from the cyl. head.
