Mf8Executive Resto And Upgrade.
207 replies to this topic
#16 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 03, 2013 - 08:28 AM
Yesterday, I remembered, that I forgot to do something. So, prior to
painting the tunnel cover (last pc to paint) I set it on the frame, because
I had wanted to make up some extra mounting brackets for it. As it was originally,
it wasn't very well secured, hence it tended to get bent/broken and cracked.
That's when I noticed all the room ahead of the shifter, under the tunnel tin.
So, I got back to thinking about a hydraulic pump and reservoir, as there
would be enough room in there. I went hunting in the goody building
again, and found this nice little hydraulic pump. Direction of rotation looking at
the output shaft is clockwise. That makes it more challenging.
For now, I'm going to carry one putting it back together while I try to
figure out how to drive this pump.
However it's driven, I feel it needs to be clutched. Getting these Kohlers
rolling over fast enough with the starter/gen is hard enough, without
trying to turn over a cold hydraulic pump.
Edit: The pump is a HC P100. I can't find anything about it on the WWW.
I was looking to see if it's reversible. That would make things sooooo much easier.
Edited by IamSherwood, December 03, 2013 - 08:35 AM.
#17 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 04, 2013 - 01:59 AM
I couldn't come up with any ideas on how to drive
this P100 pump, without putting in a jackshaft, and using
2 belts/4 pulleys. Too much stuff taking up what little room I have.
So I went back to the goodies building, and found I had one of these pumps.
More pump than needed, and bigger. As I was searching online to see
if it could run in reverse, I came across this one. Perfect. With the valve too.
http://www.surplusce...ALVE-9-9881.axd
It's on order. 2 weeks to get here across the border.
So, here is the game plan. Green lines=mounting plate for pump.
Red=I'll double up the pulley, and drive a 4" on the pump.
Purple=pump/valve. Blue=reservoir ahead of pump under frame.
Black=control handle/linkage to look sort of like original lift handle.
Red=cylinder (I have) fits nice along side frame.
Edited by IamSherwood, December 04, 2013 - 02:24 AM.
  • MH81, sacsr, twostep and 1 other said thanks
#18 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted December 04, 2013 - 02:29 AM
Nice. So let me get this straight. Double pulley on the transaxle to run a second belt forward to the pump? You do know that you will only have hydraulics when the clutch is engaged, right? So at the end of the furrow you must remember to lift before you clutch. Of course in neutral you could get your hydraulics too. Oh, is the tank full level going to be higher than the input on the pump for priming?
Edited by wvbuzzmaster, December 04, 2013 - 02:30 AM.
  • MH81, IamSherwood and KennyP have said thanks
#19 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted December 04, 2013 - 04:38 AM
Looks like a pretty well thought out idea Will, good questions too Casey.
The fact that you will only have hydraulics when the clutch is out is actually very much like the earlier tractors with hydraulics The TO20 and 30 ferguson tractors were that way, PTO and Hydraulics would only work with the clutch up. Wasnt until the TO 35 that live hydraulics and live power found a home.
It will take some getting used to to use and a lot more shifting in and out of Neutral when using it, but it sure beats not having any Hydraulics or pumping it by hand. Interesting work around for not being able to reverse the situation and run a belt off the motor.
Be fun to see this come together, good luck Will!
  • wvbuzzmaster, IamSherwood and sacsr have said thanks
#20 KennyP OFFLINE
  • 50948 Thanks
  • 52627 posts
Posted December 04, 2013 - 07:03 AM
Sounds good, Will.
#21 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 04, 2013 - 07:10 AM
Good point, on the fluid level, Cassey. Thanks.
I guess I'll wait on building the tank, until the pump gets
here. If I shift the pump back a bit, the tank should fit
ahead of it. It'll be tight. The battery sits on the frame ahead
of that cross member.
On the clutching, I'm Ok with it. For the amount of plowing I'll be doing, I
can take the time to flip it into neutral.
  • MH81 and wvbuzzmaster have said thanks
#22 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 06, 2013 - 07:12 AM
All the hydraulic activity is on hold for now till I get all the parts
rounded up.
Yesterday, I installed the motor, throttle/choke cables, new voltage
regulator and solenoid. Also got all the wiring done, except the start
push button. Had to order a new one of those. Headlights will get
hooked up later too.
Today, I'll take a look at the exhaust, and gas tank. I want to move the
gas tank forward about an inch. As OE, it's too close to all the wiring
behind the dash. A bit of a short/fire hazard.
  • KennyP, motobreeder and twostep have said thanks
#23 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted December 06, 2013 - 07:24 AM
That does look tight in there. If you can't move it, maybe a sheet of rubber or some kind of plastic in there?
  • IamSherwood said thank you
#24 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted December 06, 2013 - 07:28 AM
Are these Massey tractors built by Moto Mower?
Looking at the frame and rearend, they are oh-so similar.
Here is my Porter-Cable which is the same as a Moto Mower
Porter-Cable
#25 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 06, 2013 - 07:39 AM
Porter-Cable
Yes, Dura Corp built these and the Moto-Mowers. Same thing as
my MM 6024 except for the grill.
#26 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 06, 2013 - 07:41 AM
I think I can shift it almost 1 1/2". That'll be comforting.
#27 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted December 06, 2013 - 09:44 AM
Will, dont worry about it. On my larger Springfeilds and Toros the tank is so tight on the dash i cant gas it up without splashing gas on the wires which touch the tank 100 percent of the time lol.
Im planning to repower one and will be moving it's gas tank well away from the dash so I can add gauges.
#28 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 07, 2013 - 07:31 AM
Didn't get much done yesterday. Here's some pics of wiring, and
muffler. I think I'll brace it from the clamp, down to the engine where
the throttle cable is clamped.
  • DH1, Gtractor, sacsr and 5 others have said thanks
#29 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted December 07, 2013 - 07:56 AM
Oh good grief.... Yeah, slacker. :wtf: you got more done yesterday than I have in the last three weeks.
Folks, you have to remember, Will is so far north that the "days" up there are 5 or 6 of ours long during the winter... Or do I have that backwards? Which way do your toilets flush again???
I'm so confused, I need coffee...
  • bgkid2966 and twostep have said thanks
#30 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 07, 2013 - 08:16 AM
You've got it right Alan, days are shorter, but they are also metric. They haven't come
up with a conversion table for that yet, so, we can't really compare.
  • MH81, HowardsMF155, bgkid2966 and 1 other said thanks
