Anyone Have A Columbia?
19 replies to this topic
#1 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted November 29, 2013 - 06:08 AM
Hello, new guy here so Im snoopin around a bit, I have '75 Columbia which is basically an MTD 960, its my main work horse around the yard, has dozer,mower, tiller, cultivator and plough, a winch on both ends because Im too old and lazy to lift anything manually, I rarely use the mower but everything else gets alot of use, Im a metal fab guy by trade so the lift system on the front is my own design and handi work. One of these days I need to give it a paint job but it hardly gets a day off so not sure when thats gonna happen.
  • MH81, Texas Deere and Horse, HowardsMF155 and 3 others have said thanks
#2 KennyP ONLINE
  • 40,232 Thanks
  • 46,811 posts
Posted November 29, 2013 - 06:17 AM
That looks like a worker. If you get the chance, show us those winch setups. That sounds interesting.
  • Sawdust said thank you
#3 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted November 29, 2013 - 07:15 AM
Kind of crappy pics but its all I have at moment... the rear winch mount is very basic, just a platform positioned over the 3pt to lift the tiller, the front mount is more heavy duty and includes the dozer arm and a support going back under the tractor to a crossmember on the frame directly under the pto, you can just see a bit of that crossmember behind the front tire in the first pic I posted, everything is 1/4 plate so it can take a beating, I put the tractor in 4th at full throttle and go, fluid filled atv lugs and weights so it moves snow pretty well and the blade lifts quite high so I can pile the snow quite high as well. I used it all last winter and the only change since then was to swap out the front winch for a nice little Warn instead of the princess auto special.
  • KennyP, HowardsMF155 and sacsr have said thanks
#4 MH81 OFFLINE
Meaty looking tractor.
Those big MTDs have a lot of go get em.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted November 29, 2013 - 07:21 AM
I love that winch design.  You'd better be careful, you might have orders to make some before we all are done.
Ben W.
#6 KennyP ONLINE
  • 40,232 Thanks
  • 46,811 posts
Posted November 29, 2013 - 07:39 AM
Nice design! I like that it lifts the blade high! I'm sure other folks will have questions about the lift system. Thanks for getting the pics up so soon!
#7 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted November 29, 2013 - 07:46 AM
Welcome and thanks for posting pictures! Nice looking set up! Glad to have you on board!
#8 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted November 29, 2013 - 07:53 AM
That is a pretty slick setup on the winches, might have to take some walk-around videos and show them in more detail :D
#9 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted November 29, 2013 - 08:41 AM
:welcometogttalk:   Great job on the winches. :rocker2:
#10 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted November 29, 2013 - 10:08 AM
Great fab work for the winch set-ups.
#11 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted November 29, 2013 - 04:28 PM
Thx for all the compliments guys, I'll try gettin the Columbia up on blocks and take a few pics of the front lift, it could be replicated with basic fairly metal working tools. I have an easy option for punching out the pieces but a torch will do. I just have to put the pieces on paper, take that to one of autocad experts upstairs at work, then load a sheet of 1/4 plate into a very nice cnc punch/shear machine and then go weld them together. The crossmember under the frame was the only piece bent in a press but it can be done with welded pieces also. Its basic design could be easily modified to fit many tractors I would think, I know it goes onto a Ford LGT quite nicely.
If ne1 is interested google "Finn Power Shear Genius 8", that should find some cool videos of my punch at work, as well as "E-Bender 5"... also by "Finn Power". Didnt have such toys when I first got into metal fab but they sure make things easy today.
#12 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted November 29, 2013 - 09:36 PM
Grabbed a few pics of the front lift and started a thread in the attachments forum...
http://gardentractor...ted-blade-lift/
  • MH81 and sacsr have said thanks
#13 HALFSCALE OFFLINE
HALFSCALE
  • 508 Thanks
  • 534 posts
Posted December 01, 2013 - 12:39 AM
Great to see your Columbia, especially a gear drive . The unique thing (other than they used a different grill ) is the gear drive Columbia had their own fenders, it's similar to the 990 but they are different , and I know of no other MTD that used that fender.
Dad has two Columbia's ,a 16hp gear drive and an 8hp gear drive, kinda hard to come by down here.
  • Lance Skene said thank you
#14 Lance Skene OFFLINE
Lance Skene
  • 487 Thanks
  • 337 posts
Posted December 01, 2013 - 12:33 PM
Just a guess on my part but I thought the 990 and 960 have differant fenders simply because they have differant size rear wheels, Im pretty sure I have seen pics of other mtd 960s with the same fenders as my Columbia.
Does the 8hp model have the same frame as the 16hp model? My book covers a 10hp and 16hp but no mention of an 8hp model.
#15 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted December 01, 2013 - 07:31 PM
Just for reference:
Hydro (990) fender
Standard MTD gear drive fender:
As mentioned, the 16hp Columbia gear drives use a fender that looks like the hydro fender.
As far as any other store "brands" that use the hydro fender on a gear drive... I'm sure there could be but all the pics I've seen have used the regular gear drive fender.  I know Halfscale has done quite a bit of research on these and has mentioned this in the past.  Certainly can't rule it out though.
I have a Columbia sales brochure for '75 and as you mentioned, it shows gear drives in 16hp (960) and 10hp (760).  MTD also offered an 860 which was 12hp most years and a 660 which was 8hp.  Just a quick check of the parts manuals shows the 960 and 860 sharing a frame.  The 760 and 660 also shared a frame.
By the way, you have a nice tractor.  I'm liking the Columbia grill the more I see it.
Edited by Canawler, December 01, 2013 - 07:33 PM.
