Spark Plug
8 replies to this topic
#1 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted November 28, 2013 - 10:56 AM
Hi guys , need a little help figuring out the right spark plug for a kohler 160 I think it is a six and a half hp engine runs like a sewing machine once she comes alive but its getting her there that's the problem. thanks HANKG.
  • JRJ said thank you
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted November 28, 2013 - 11:11 AM
Correct spark plug is 14mm x 3/8" reach - Champion J-8 or Autolite A7.  ....If burning some oil, a slightly hotter plug can be used such as Champion J-11 or Autolite A9.
  • Bolens 1000, IamSherwood, boyscout862 and 3 others have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 28, 2013 - 02:16 PM
Bruce, I was under the impression that the K series used either a J19LM for long height or a CJ8 for low clearance?
Ben W.
  • HANKG said thank you
#4 olcowhand ONLINE
  • 40,371 Thanks
  • 31,177 posts
Posted November 28, 2013 - 05:15 PM
NGK are the opposite....colder the plug higher the number....the hotter the plug, the lower the number.  Wish things were more standardized.
  • HDWildBill and HANKG have said thanks
#5 Bolens 1000 OFFLINE
  • 14,906 Thanks
  • 18,104 posts
Posted November 28, 2013 - 08:27 PM
Ben W.
I was always Told to use a J8 .......
  • superaben and HANKG have said thanks
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 28, 2013 - 10:09 PM
That could be.  I think every small engine could use a J8C.  A CJ8 is still just a short J8C, so if Kohler is saying J19LM or a CJ8, the J8C would probably work just fine.  I know I have used J8C across the board on most old engines.
Just now looked up the number, K161 uses 41 132 06 which has become a J19LM.  I think that is nearly identical to a J8C in terms of heat and so forth, so we are probably both right.
Ben W.
  • Bolens 1000 and HANKG have said thanks
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted November 29, 2013 - 12:08 AM
Ben W.
Just for clarification:  Champion J-8 was the long plug with 13/16" hex, while CJ-8 was the shorter version with a 3/4" hex, but otherwise the same as the J-8.
The J19LM was a "universal" plug for small engines, but they had a higher failure rate (cheaper quality?)  when we were selling them, so we stopped handling them.
A J-8J plug was the same as the J-8, except the ground electrode did not extend all the way across the center electrode.  ....These plugs were recommended for 2-cycle engines, as they were less prone to fouling.   .....The CJ-8J was a shorter version of the same plug, but with a smaller hex.
 I am not familiar with the J8C designation.  ...Perhaps it is just a newer numbering system for the J-8 ????
  • MH81, drbish, superaben and 1 other said thanks
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 29, 2013 - 07:22 AM
Bruce, thanks for the info.  I had heard that a lot of the older shops were not fond of the more modern plugs in use for old engines.
J8 did become a J8C.
Ben W.
#9 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted November 29, 2013 - 09:57 AM
Thanks for the help guys my arm also said thanks. Hankg.
