12" Wheel Weights
7 replies to this topic
#1 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted November 27, 2013 - 07:02 PM
Just picked up 5----30# vibration dampeners for a CAT diesel.
Think they will make good wheel weights? I hope so, as they cost me $20!
  • olcowhand, Texas Deere and Horse, wvbuzzmaster and 3 others have said thanks
#2 KennyP ONLINE
  • 38,385 Thanks
  • 45,935 posts
Posted November 27, 2013 - 07:05 PM
Cool weights! The right size too!
#3 olcowhand OFFLINE
  • 41,194 Thanks
  • 31,428 posts
Posted November 27, 2013 - 07:08 PM
Those will make great weights!  Maybe weld on 3 or 4 tabs around the perimeter to keep the weights from moving.
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted November 27, 2013 - 07:55 PM
Would make nice inner weights if the fit over your rear axle hubs. Nice find!
#5 olcowhand OFFLINE
  • 41,194 Thanks
  • 31,428 posts
Posted November 27, 2013 - 08:05 PM
You know Troy, they look like the inner portion is thinner, so one could torch out the thin centers, then they would fit over any hub.
#6 MH81 OFFLINE
Posted November 27, 2013 - 09:59 PM
Nice haul for $20.
They should do nicely.
The 12" may not sit back in, you may need to put a std weight in first, then these.
#7 olcowhand OFFLINE
  • 41,194 Thanks
  • 31,428 posts
Posted November 27, 2013 - 10:12 PM
Nice haul for $20.
That's how I did when I used the Farmall weights.  I first put a set of Bolens style weights that fit totally inside the rim center, used extra long all thread, used nuts to hold those weights snug, then slid on the Farmall weights, then another set of nuts to lock them.
#8 Grumpy OFFLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted November 28, 2013 - 08:57 AM
Looing good. bring them down and I'll drill them for you.
Grumpy
