John Deere 140 Resto
john deere 140
11 replies to this topic
#1 BillBaker55 OFFLINE
BillBaker55
  • 2 Thanks
  • 3 posts
Posted November 26, 2013 - 08:49 PM
I have started to try and fix up an old john deere 140. I started by replacing the battery and that is as far as I have gotten. The battery was installed and there was nothing when I turned the key. I just want to know what I should try to fix first or if I need to start an extensive parts list. I am new to this thing and I welcome any help.
  • A.C.T. and Dieselcubmike have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,969 Thanks
  • 10,002 posts
Posted November 26, 2013 - 08:57 PM
Do you have a voltage tester? Time to start checking connections on the wiring, and then checking where and when you have power.
  • BillBaker55 said thank you
#3 BillBaker55 OFFLINE
BillBaker55
  • 2 Thanks
  • 3 posts
Posted November 26, 2013 - 09:06 PM
Thank you I will start there.
#4 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted November 26, 2013 - 10:02 PM
What year is the 140?  Do you have a serial number?  There are some significant wiring differences based on the serial number of the machine.  Does it have an external coil or magneto ignition?
#5 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted November 26, 2013 - 10:47 PM
Unless some one has changed the motor, it has a external coil.   With the key in the on position, a volt meter should read about 12 volts at the coil.  When u turn the key, do u hear a click sound and nothing happens, or does just nothing happen.   A click sound would mean the starter solenoid is getting voltage.  If no click is heard, check for voltage at the starter solenoid.  Corrosion and or loose connections  can cause nothing to happen when u turn the key. When u check for corrosion or loose connections, disconnect the battery first.  I will post a pic of the wiring diagram asap.
#6 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted November 26, 2013 - 11:23 PM
you can have a bad pto safety and/or a netual-starter switch that are bad
there are located between the starter switch and the coil
if one is bad it does not allow the current to the coil
some of the 140 have a electric pto clutch - which has an electric switch - which can also be bad
you should check the wiring and switches with an ohm meter
look at the wiring diagrams - they should help you with the wiring
without electric pto
with electric pto
Edited by lyall, November 26, 2013 - 11:28 PM.
  • jimbobbillyray said thank you
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted November 27, 2013 - 12:09 AM
Welcome to GTT, Bill
#8 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted November 27, 2013 - 12:36 AM
Hello and welcome :wave:
#9 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted November 27, 2013 - 07:16 AM
And please test the key switch. We were at a fair and my 112 didn't start, some month ago. We didn't find a failure. We thought, the key switch could be damaged....
Some days later, we were back at home again, the tractor started...
#10 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted November 27, 2013 - 08:22 AM
Welcome! I have a 140 and sometimes need to wiggle the hydro lever in neutral.
#11 BillBaker55 OFFLINE
BillBaker55
  • 2 Thanks
  • 3 posts
Posted November 27, 2013 - 01:52 PM
Thank you so much for all this help. i took the volt meter out today put the battery on and tightened it down. Then the tractor turned over. Which was a great sound. This tractor was my grandfathers and he passed a year ago.
Now I have to deal with the Stuck Carb. Any suggestions on how to get that unstuck i was thinking Wd-40
Edited by BillBaker55, November 27, 2013 - 01:54 PM.
#12 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted November 27, 2013 - 05:19 PM
glad for the update about your 140
for freeing up a carb you might want to soak for a few day
some use lemon juice, pine sol and other thing
there was a post about clean a carb here lately about it
I think I found  the post, but there can be others post about it
http://gardentractor... carb cleaning
Also tagged with one or more of these keywords: john deere 140
