Tracked Snow Blower
6 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 26, 2013 - 06:26 PM
Any one have or used one of these outfits? The prices are starting to come down on them around my area, just curious if they are decent blowers. I know there are many different types and brands. I have heard they are harder to handle than your typical wheel type blower. How heavy is the drive system?
  • JRJ said thank you
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted November 26, 2013 - 08:05 PM
Much heavier. I had a Honda that took everything I had to lift it into a truck bed. The paddles (treads) on the tracks are flexible, they grip as well as tires with chains. Almost. Better than snow hogs.
#3 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted November 26, 2013 - 08:10 PM
I have a track drive blower I got from my father about 15 years ago.  It was about 20 years old then.  It is solid & heavy.  Has a Tecumesh engine that starts every time.  It is basically the same as a regular blower inside, except the final drive axle has a track drive gear on it instead of a wheel.  One huge negative is that it is a brute to move.  The track doesn't free-wheel, so it either moves under its own power or you have to drag it, pushing it is out of the question.  I finally built a cart for moving it around in the garage.  One plus is it will climb stairs.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted November 26, 2013 - 08:43 PM
I have never used one, but I would say that if it is anything like a tracked skid loader, it is useless on snow.  It will pack what it doesn't blow, and then as it scoots around it will create a skating rink.
I might be wrong, like I said I have never used one and it might not be heavy enough to be like a track loader, but I'd be curious to hear if anyone else has seen something similar.
Ben W.
#5 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted November 26, 2013 - 09:37 PM
Mine doesn't pack the snow under it.  If anything, the treads breaks hard-pack into small pieces.  It also has a tilt lock that keeps the bottom of the blower dead level with the bottom of the track so it keeps the blower on the driveway surface.  Unlock the tilt & you can do anything a normal blower will do.
#6 chuckerfarm OFFLINE
chuckerfarm
  • 27 Thanks
  • 47 posts
Posted November 27, 2013 - 04:58 AM
All companys seem to be offering the tracks and most have power steering!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
#7 shorty ONLINE
shorty
  • 5,774 Thanks
  • 5,390 posts
Posted November 27, 2013 - 05:22 AM
I got to run a tracked blower when I helped a crew a few years ago. I was impressed with the handling of it. The track had cleats on it, kind of snowmobile track style, and there was little slipping. If you have to do a lot of turning, it is a bit harder with tracks. We had a lot of long side walks to do and it worked great for that.
