3-Pt Gannon Earthcavator - N. C. Craigslist
This topic has been archived. This means that you cannot reply to this topic.
22 replies to this topic
#16 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,283 Thanks
  • 3,292 posts
Posted November 28, 2013 - 10:11 AM
I guess it is a limited Cat-1. The holes are for a Cat-1 but the spacing seems a little tight about 21" just inside the first mounts.
I want to use this on a Cat-0 tractor. Interested in any ideas on how to do this.
#17 KennyP OFFLINE
  • 29,403 Thanks
  • 40,398 posts
Posted November 28, 2013 - 10:20 AM
Scott, I have gotten some Cat 0 pins that had lots of thread on them at TSC or our local Atwoods (farm supply). They also have Cat 1 to Cat 0 bushings at times. Here's another place for the pins.
#18 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,283 Thanks
  • 3,292 posts
Posted November 28, 2013 - 10:48 AM
Kenny my implement does not have pins. It has two brackets that the arms slide in between and then the pins are pushed through. What I might do is weld one end of the cat-0 pin with a bushing and a washer to stop it from going through, then have a bushing on the other end with a hole drilled through it and the pin so I can lock it in place. I suspect if it is ever sold, better chance it will be some one with a Cat-0 hitch than a Cat-1. So maybe just go ahead and cut the brackets off and build a Cat-0 setup instead
#19 OldBuzzard OFFLINE
OldBuzzard
  • 6,565 Thanks
  • 4,649 posts
Posted November 28, 2013 - 12:51 PM
Why do any cutting and/or welding?
Looks like you would be able to use a set of CAT 0 lift arm pins on the inside tabs, and point them to the inside.
There should be room to slip the nut in between the tabs.
#20 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,283 Thanks
  • 3,292 posts
Posted November 28, 2013 - 01:39 PM
Ahhhhhh. So Kenny's suggestion was right- I was not thinking about being able to face the pins to the inside. That should work! Thanks OB and Kenny!
#21 KennyP OFFLINE
  • 29,403 Thanks
  • 40,398 posts
Posted November 28, 2013 - 02:26 PM
Guess I should have been clearer with my suggestion, Scott! But that is what I was thinking since you have 21" between them,
#22 olcowhand ONLINE
  • 36,178 Thanks
  • 29,972 posts
Posted November 28, 2013 - 05:29 PM
You have a nice attachment there Scott, one that will see use I'm sure!
#23 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,283 Thanks
  • 3,292 posts
Posted November 28, 2013 - 10:03 PM
Did some research. This particular gannon was made for the Kubota b6000 and the ford 1220.
42" about 158 lbs. I found a posting on a Cub Cadet forum that spells out what the model numbers represent.
Here is the link. http://www.ihcubcade...html?1267195183
Still would like to know what years they were made.
Well I was going back over the spreadsheet and I obviously can't read well on my phone. Upon further inspection, mine is a Cat-0 with Cat-1 pins - not for specifically for a a Kubota or ford. That model is 2 rows farther down on the spread sheet. Mainly just want to set the record straight for future reference.
