Heat Lamps
18 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 25, 2013 - 06:42 AM
Has anyone used a heat lamp on their diesel to achieve easier starts on very cold days?  I didn't get a block heater put on the Massey when I bought it because I figured I could use something like a light bulb of small ceramic heater to give it a boost.  It was pretty cold here yesterday and the tractor started with no problems.  I'm just looking to give it easier cold weather starts.  Thought a heat lamp might be a good choice.  Opinions?
  • hamman, Dieselcubmike and JRJ have said thanks
#2 Alc ONLINE
  • 7,240 Thanks
  • 7,587 posts
Posted November 25, 2013 - 06:50 AM
We have one of these lower radiator hose heaters on the fork lift at work , not much $$ if you have the room and can get the correct size
http://www.fleetfarm...CFWJo7AodcmsAPQ
  • nra1ifer, MH81, hamman and 2 others have said thanks
#3 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 25, 2013 - 06:54 AM
I use a magnetic block heater on the GTs.
Works fine. It's a bit tricky though trying to get it
to stick to the aluminum blocks.
  • MH81, hamman, David Brown and 1 other said thanks
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 25, 2013 - 07:08 AM
My main problem (and a bit of a surprise) is that once I got the tractor started, I couldn't go above idle.  The tractor would do it but not from the throttle.  The cable froze or something.  I have to look today because it may have gotten pinched or something.  Can't imagine what on but you never know.  Not a big deal, just a speed bump in the learning curve.  I just figure a heat lamp under the tractor will eliminate that and give it an easier start.  Got a snow storm coming in tomorrow and my old plow tractor is gone.  It's been years since I've relied on a diesel in the winter so I have to get acclimated to it's little quirks before I am comfortable.  They do kick up quite a fuss on a cold weather start, don't they?
Edited by David Brown, November 25, 2013 - 07:09 AM.
  • Alc, hamman and JRJ have said thanks
#5 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 25, 2013 - 07:18 AM
Take your hair dryer to the throttle cable.
Oh hang on a second. You took your hat off when we had
lunch at WPGTA plow day.
Take your wife's hair dryer to the throttle cable.
  • olcowhand, MH81, Alc and 6 others have said thanks
#6 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 25, 2013 - 07:23 AM
LOL I was going to say something, but you beat me to it.  Can you tell I raised two girls?  I had a full thick head of hair before they learned to make 32 ponytails on one head!  My eyes still haven't returned to their normal shape.
  • hamman, IamSherwood and JRJ have said thanks
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted November 25, 2013 - 07:28 AM
:rolling: Will, just because he's a member of the "Hat Club for Men" ...
I would think a new tractor with good glow bars should start, but I agree on making it as easy as possible.
They used to sell dipstick heaters when I was a kid... I wonder if they still do?
  • hamman, David Brown and JRJ have said thanks
#8 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted November 25, 2013 - 07:34 AM
From the same FleetFarm site:
http://www.fleetfarm...ategoryId=02319
  • MH81, Alc, hamman and 3 others have said thanks
#9 IamSherwood OFFLINE
  • 8,395 Thanks
Oh, please dig up a picture of that. You, with 32 pony tails would
be an interesting look.
Honestly, we won't laugh. :smilewink:
#10 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 25, 2013 - 07:35 AM
Well, like I said, the problem is not starting.  It start right up in spite of me.  Having never had a new tractor, I want to take care of this thing so it lasts as long as possible.  You know, pass it down to my kids and such.  They won't have a clue as to what to do with it but whatever.  The Satoh has a block heater and still has a lot of problems starting in the cold.  That's why I put it away for the winter.  This one starts up great.  I just want to give it easier starts.
Oh, and you're right, I am a member of the hat club for men as well as a charter member of the social network site "Nobody wants to see my FACE...  BOOK".  My wife like it when I grow my beard.  I tell people that she likes as much of my face covered as possible.
  • MH81, hamman, KennyP and 2 others have said thanks
#11 MH81 OFFLINE
  • 29,979 Thanks
Posted November 25, 2013 - 07:36 AM
Yes, they still do... Wonder how well they work?
http://www.ebay.com/...heater&_sacat=0
  • hamman and JRJ have said thanks
#12 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 25, 2013 - 07:37 AM
I'm afraid I'll have to leave that one to your imagination as all printed material has been destroyed.  This was before the digital age.
#13 boyscout862 ONLINE
  • 13,556 Thanks
  • 9,431 posts
Posted November 25, 2013 - 07:51 AM
I would also suspect the fuel may have "gelled" abit. It has happened to my 71 Ford 2000 diesel. The fuel strainer was blocked by thick fuel. I have used an old comforter over the engine and a 100w drop light to keep an engine warmer for easier starting. Keep the heat source low to let the heat rise through the engine. I then cover the entire tractor with a tarp to keep out breezes. It helps alot. Substituting a 200w magnetic heater onto the bottom of the oil pan works even better. Of course a 5 bay heated garage would be best. Good Luck, Rick
Edited by boyscout862, November 25, 2013 - 07:52 AM.
#14 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 25, 2013 - 07:56 AM
If it had trouble starting, I would say it may have gelled.  I have an additive in the fuel to prevent that.  It's in the shed, not outside.  This is a throttle cable issue only.  Throttle works great, cable, not so much.  Tractor starts and runs as it should.  I do plan to put the heat lamp under the tractor to let the heat rise and do it's thing.  I suppose a regular light bulb (remember those?) would do the trick but I felt the heat lamp would work a little faster.  Just wondering in anyone used one and what kind of luck they had with it, that's all.
  • hamman, boyscout862 and JRJ have said thanks
#15 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted November 25, 2013 - 01:01 PM
You can keep a heat lamp under it to keep the oil pan warm and the rest of the block too from the rising heat. Also, the glow plugs are a great asset on diesels since they help it during the winter to start by heating the air in the intake manifold. what you could do also is put a heat lamp under the rear end so it keeps the oil warmer and flows better to keep everything lubed while your out playing in the snow.
  • David Brown said thank you
