Where To Get Ignition Switches?
13 replies to this topic
#1 Oregon_Bolens OFFLINE
Oregon_Bolens
  • 149 Thanks
  • 171 posts
Posted November 24, 2013 - 08:11 PM
I need a switch for 2 1556's, and a 1050. Sam Bolens doesn't have it, and I've never seen any on EBay...and ideas?
#2 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 7399 Thanks
  • 3126 posts
Posted November 24, 2013 - 08:13 PM
Take the old one to NAPA. You need to make sure they are the same. Make sure the posts on the replacement switch are labled like the old one. Take if from someone who has had this experience. Good Luck. Roger.
  • boyscout862 and Oregon_Bolens have said thanks
#3 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 24, 2013 - 08:16 PM
The 1050 Used a different switch than the 1556
How many terminals are on the 1556 switch?
  • Oregon_Bolens said thank you
#4 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
These switches are not available at Napa. Bolens used a unique switch. They are available but very expensive. I found an NOS switch on ebay.
I believe Bob has them
  • hamman and Oregon_Bolens have said thanks
#5 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 24, 2013 - 08:17 PM
In all my years of trying, I have yet to find any Napa aftermarket for any of the special Tubeframe switches.
Do not worry though , they are still available but are expensive!
#6 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted November 24, 2013 - 08:50 PM
What's special about these switches, Dr. Bolens?  Do you have a diagram of sorts I could try to match?   I have a Stens account and a Rotary type parts account that I can drag parts from, as well as a distributor for most common brands.
Somebody may have already tried lawn and garden aftermarket, I ask from ignorance only, and a belief that if you can't try everything, it isn't worth hunting for.
Ben W.
  • sacsr and boyscout862 have said thanks
#7 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted November 24, 2013 - 09:03 PM
Bob's Lawn & Garden (one of our site sponsors) has some parts for Bolens.  Might give him a shout.
#8 farmerall OFFLINE
farmerall
  • 2260 Thanks
  • 1495 posts
Posted November 24, 2013 - 09:10 PM
I had to get a new switch for my 1050 before and went to a OPE shop and got a new one from there. The 3 prong switch isn't made any more but you can use a 5 prong one as long as it has the same terminals as the original switch. You will need a switch for battery ignition, this is a different switch than the one needed for a magneto ignition. The only thing that will need to be changed is the wire connectors because the new switch will need slide on connectors.
#9 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted November 24, 2013 - 09:11 PM
I have the switch for the 1050 will have to look and see if I have the 1556 one.
  • boyscout862, superaben and Oregon_Bolens have said thanks
#10 Oregon_Bolens OFFLINE
Oregon_Bolens
  • 149 Thanks
  • 171 posts
Posted November 24, 2013 - 10:23 PM
Thanks for all the replies. I've tried Sam's, and Bob's. The 1556 is a 5 prong. I'll snap a picture tomorrow. I'd really like to keep it original and not bypass the safeties.
#11 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted November 24, 2013 - 10:52 PM
Just had some nos stuff come in and will see if there is some switches in it. As I said I do have the 3 prong for the 1050 tractor.
#12 Oregon_Bolens OFFLINE
Oregon_Bolens
  • 149 Thanks
  • 171 posts
Posted November 24, 2013 - 11:18 PM
Bhts, good to know on the 1050. I'll pm you for more info...
#13 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted November 24, 2013 - 11:49 PM
Hi, will also check on the one for the 1556 for you
#14 Oregon_Bolens OFFLINE
Oregon_Bolens
  • 149 Thanks
  • 171 posts
Posted November 26, 2013 - 08:12 PM
Here's a terrible pic...one of the tabs broke off of this switch...otherwise it worked. This is for the 1556. Wiring is not stock, but hope it will be soon.
