Need Help With A Vertical Shaft Briggs Carb And Governor
3 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted November 24, 2013 - 06:57 PM
1970s Briggs vertical shaft 7 hp engine with issues, the governor doesn't seen to hook to the carb or throttle, as in nothing seems to operate together. Secondly, I don't like the stock carb, want a side draft on it. Thinking that plus bypass the governor all together. Not working the tractor, or mowing with it, just joy riding. What is everyone using to do this, or rather, what do I need lol.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted November 24, 2013 - 08:52 PM
Casey, what engine do you have first of all?
Second, what do you mean that nothing operates together?  Is the engine hunting or is it just not hooking up right?
I would be careful bypassing the governor.  Briggs engines are not airplanes.  They will go boom fast.
Ben W.
#3 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted November 24, 2013 - 08:56 PM
No hunting. The throttle is hooked to the gov plate, the carb is hooked to gov linkage. Nothing seems to move each other ever...
Will run out and take pics and get the numbers off of it.
#4 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted November 24, 2013 - 09:32 PM
The one I am working on and dislike the carb setup
that engines info
Now a reference of what the factory setup for this tractor was.
