Dual Transmission Question
10 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 24, 2013 - 06:42 PM
In a dual transmission power king which one changes the gears from forward to reverse?
#2 DougT ONLINE
DougT
    Dog Approved
  • 7,110 Thanks
  • 5,075 posts
Posted November 24, 2013 - 06:48 PM
Either one would be capable of reverse. It gives you 3 speeds backwards. If you put both trans in reverse you would go forward.
  • IamSherwood and Bob IN have said thanks
#3 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted November 24, 2013 - 06:51 PM
Both transmissions are exactly the same. If you want to go in reverse, you can put either one in reverse, and the other will change how fast you back up.
Third gear is a 1:1 ratio, so if you have either one in third gear, it is virtually the same as having a single tranny tractor.
  • IamSherwood, Dieselcubmike and Bob IN have said thanks
#4 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 24, 2013 - 07:13 PM
Thank you. That makes since.  :thumbs:
#5 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted November 25, 2013 - 08:57 AM
Here's a spreadsheet that I made listing gear ratios and tractor speeds with the single trans and tandem trans tractors.
Since both transmissions are the same there is a lot of duplication. In the end you are gaining 2 slower speeds-Both trans are in 1st, one trans in 1st and the second trans in 2nd. When both trans are in 2nd, the result is very close to one trans in 1st and the second in 3rd.
Hopefull the attachment will be easy to read.
Attached File  PowerKing Gearing.pdf   158.01KB   207 downloads
Edited by EconChuck, November 25, 2013 - 09:02 AM.
  • Alc and Austen have said thanks
#6 dpbcc OFFLINE
dpbcc
  • 12 Thanks
  • 20 posts
Posted September 19, 2017 - 07:53 AM
I know this is an old thread but I tried download the gearing pdf but got a file not found message?   Anyone have a copy?  I'm looking at  a twin tranny power king and this would be really helpful.
Dave
#7 KennyP ONLINE
  • 40,865 Thanks
  • 47,088 posts
Posted September 19, 2017 - 08:26 AM
That's what happens sometimes with manuals in posts. I looked and it's not in the PK section of the manuals and I do not have a copy. Maybe someone who downloaded it will repost it ( or put it into the manuals section).
  • MNGB said thank you
#8 MNGB ONLINE
MNGB
  • 2,616 Thanks
  • 1,566 posts
Posted September 19, 2017 - 01:14 PM
Hi dpbcc, I don't know if this is the same as the original file but this is what I have
  • Austen said thank you
#9 MNGB ONLINE
MNGB
  • 2,616 Thanks
  • 1,566 posts
Posted September 19, 2017 - 01:20 PM
Hi Kenny I uploaded that file to the manuals section hopefully its right if not you'll have to straighten out GB
  • KennyP and dpbcc have said thanks
#10 KennyP ONLINE
  • 40,865 Thanks
  • 47,088 posts
Posted September 19, 2017 - 04:28 PM
It opens just fine for me!
#11 dpbcc OFFLINE
dpbcc
  • 12 Thanks
  • 20 posts
Posted September 20, 2017 - 10:17 AM
Thanks, that is just what I was looking for - terrific job to whoever worked it out?
