Oil Seal Question
3 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted November 24, 2013 - 04:30 PM
I have the Waterloo Model 15 torn apart for painting.  The transaxle has one (1) oil seal in it.  Not sure why, but it does.  Anyway, it is shot & needs to be replaced.  It is the older felt style which seam to be NLA.
The problem is that the axle has a factory cut notch for the oil seal to ride in.  The axle is 1" OD, and the groove is about .975" OD.
The question is: should I go with an oil seal that has a 1" ID (SKF 9843) and hope it doesn't leak (or install with a speadi-sleeve), or one that is .984" ID (SKF 9686) and hope it doesn't tear going on?
Edited by New.Canadian.DB.Owner, November 24, 2013 - 04:33 PM.
#2 boyscout862 ONLINE
  • 12,869 Thanks
  • 9,180 posts
Posted November 24, 2013 - 05:04 PM
There are plastic sleeves to use for installing the seal. Try to find one of the correct size. Good Luck. Rick
#3 DougT OFFLINE
DougT
    Dog Approved
  • 6,931 Thanks
  • 4,997 posts
Posted November 24, 2013 - 06:57 PM
I'd say you are probably going to have to use a speedi-sleeve. I'd almost think the shaft is wore there. Doesn't make much sense to cut that recess for a seal to ride in. The .984 is still going to be .009 too big. Would there be a possibility that the new seal could be put in farther out to ride on a differrent part of the shaft and get by with the 1 in.?
#4 Cvans OFFLINE
  • 6,668 Thanks
  • 6,134 posts
Posted November 24, 2013 - 07:43 PM
1" and the speedi sleeve.
