Bolens Weight...what Does It Fit?
7 replies to this topic
#1 PappyH OFFLINE
PappyH
  • 35 Thanks
  • 53 posts
Posted November 24, 2013 - 03:08 PM
Picked up a very heavy weight this  weekend but have no idea what it is from or for.  Anyone know?  Marked Bolens.
#2 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted November 24, 2013 - 03:17 PM
That's for the Bolen EK series.
It mounts on the hitch and you put a pin/bolt through the hole to secure it.
If I remember right, those are in the neighborhood of 85 Lbs.
Edited by OldBuzzard, November 24, 2013 - 03:17 PM.
  • PappyH said thank you
#3 Bolens 1000 ONLINE
  • 17301 Thanks
  • 18797 posts
Posted November 24, 2013 - 06:03 PM
:ditto:
Its the counter weight for the Estate Keepers
#4 UncleWillie OFFLINE
  • 16500 Thanks
  • 9061 posts
Posted November 24, 2013 - 06:36 PM
I am going to go out on a limb and say it fits a Bolens
:D :smilewink: :D :smilewink:
#5 PappyH OFFLINE
PappyH
  • 35 Thanks
  • 53 posts
Posted November 24, 2013 - 09:01 PM
Any real value to it?  I seem to be finding Bolens stuff I can't use and has no value.
#6 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted November 24, 2013 - 11:52 PM
Yeah, it could have some value.
The EKs did havea snow blade and a snowcaster for them.
If someone has an EK and one of both of those attachments they could want it.
There's just not that many EKs out there as compared to the tube and large frames, and probably fewer still that have the blade and/or 'caster attachments.
#7 PappyH OFFLINE
PappyH
  • 35 Thanks
  • 53 posts
Posted November 25, 2013 - 09:11 AM
Since I do not have proper wheel weights for my 1556 I may make a mount on the hitch and use this for extra weight for plowing snow this winter.  My 280lbs plus that weight and chains should be enough for my flat driveway.
#8 KennyP ONLINE
  • 50038 Thanks
  • 52259 posts
Posted November 25, 2013 - 02:41 PM
That should work!
