Repairing Front Attachment Lift On 425 Jd
7 replies to this topic
#1 Alberta Bolens OFFLINE
Alberta Bolens
  • 926 Thanks
  • 382 posts
Posted November 24, 2013 - 02:25 PM
I have had my 425 for 6 years and its pushed a lot of snow dirt etc.  I noticed when pushing snow last week the blade jumped around a lot, seemed loose.  I checked it out and realized there was wear around the pivot point holes.
So after some thought I came up with a plan.  I would add plate to top and bottom of pivot drill out hole and add longer bolt.
Ignore the bubble gum welds.
The lift pivot was worn out also.  I decided to weld some nuts to the frame.  I drilled hole for cotter pins and drill out threads of the nuts.
Added bit of spray paint to hide the welds and it seems to work.  Not rattles and way tighter now.
Anyone spot the mistake???
Edited by Alberta Bolens, November 24, 2013 - 02:26 PM.
  • JRJ and superspeedex have said thanks
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 24, 2013 - 03:11 PM
Looks Good
  • JRJ said thank you
#3 jms180 OFFLINE
jms180
  • 1,753 Thanks
  • 1,675 posts
Posted November 24, 2013 - 03:44 PM
Great job nice when a plan comes together
#4 Alberta Bolens OFFLINE
Alberta Bolens
  • 926 Thanks
  • 382 posts
Posted November 24, 2013 - 05:50 PM
Have a good look at the photo's.  There is one photo with a goofy mistake in it.  Can anyone find it?
#5 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,142 posts
Posted November 24, 2013 - 06:41 PM
Are you referring to pulling up to the hitch the wrong way and taking a pic?
#6 Alberta Bolens OFFLINE
Alberta Bolens
  • 926 Thanks
  • 382 posts
Posted November 24, 2013 - 07:05 PM
Nope its mounted on the tractor properely.
I put it together took a photo of it on the floor.  Put it back on the bench to hook up cylinders.   Realized I had it backwards.  Happy there was only on bolt
Edited by Alberta Bolens, November 24, 2013 - 07:13 PM.
  • MH81 and JRJ have said thanks
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted November 24, 2013 - 07:38 PM
Thanks for pointing it out. Now that you said it I can say "Yeah, I knew that" lol
Looks like it'll hold up for a long time like that. :D
#8 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted November 24, 2013 - 07:47 PM
Similar to a repair I had to make on an older 42" blade I had, I use a piece of pipe acting as a long washer, worked out good for me.
Dick
