1655/1855 Front Pto Part Needed
2 replies to this topic
#1 Petenpole OFFLINE
Petenpole
  • 202 Thanks
  • 168 posts
Posted November 24, 2013 - 08:18 AM
Good morning:
I am in need of the sleeve (as MF calls it) that the pto shaft slides through on the front axle.
Mine is worn  and by worn I mean sloppy loose. I had oil lite bushings cut and installed but when you tighten the 2 large nuts on each end it gets so tight you cannot turn the shaft. And that tells me the worn bore is out of center.
Short of having a new sleeve machined I would like to see if anyone has a good one and if I am extra lucky maybe they might have the PTO Shaft with it?
The sleeve I am looking for is item 3 in the attached diagram
Thanks in advance
#2 adolphsson09 OFFLINE
adolphsson09
  • 258 Thanks
  • 327 posts
Posted November 24, 2013 - 01:42 PM
Well  I tried to look at your pics but it wont let me tries to get me to buy office to look at them anyhow are you looking for the  sleeve that goes around the shaft itself and are they anything like the sleeve on the rear because I was unable to locate u joints for my rear shaft so the massey guys put a universal knuckle in and the sleeve does not work for me anymore just wondering if they are the same size just shorter
#3 Petenpole OFFLINE
Petenpole
  • 202 Thanks
  • 168 posts
Posted November 24, 2013 - 07:48 PM
well I re saved the attachment as a PDF on a different computer hoping for help
  • adolphsson09 said thank you
