Broken Heat Pump!
14 replies to this topic
#1 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 22, 2013 - 06:01 PM
One of our Split type heat pumps quit working. it just refused to start and flashed some indicator leds on the display. I decided to have a look at the connections on the circuit board on the outside unit as this has been a source of problems in some of these units. I found that this heat pump suffered a similar fate to many a GT that is left outside. MICE!!  :mad2:  :mad2:
  They got in through a tiny hole near the refrigeration lines and built a nest smack on top of the circuit board. It's quite a mess. There are wires and components chewed through and corrosion and filth all over the board. I'm going to try to fix it but it's a bit of a long shot. I do like a challenge though.
Here's some photos. The last picture is after washing the board with warm water. There is still a lot of crap stuck to it. Disposable gloves and a mask were mandatory! I've got it cleaned up now and there are a half dozen or so resistors and ceramic capacitors that need replacement. That is just what I can see at a glance. Fortunately the board is labelled with all the part values. The nest is made almost entirely of dog hair from our 2 standard poodles. My wife scatters it at the edges of the yard in an attempt to keep the deer away.
  • Alc, KennyP, bgkid2966 and 2 others have said thanks
#2 Alc OFFLINE
  • 6,886 Thanks
  • 7,461 posts
Posted November 22, 2013 - 06:21 PM
Sorry to hear such of mess , I hope your post reminds others of the problem mice can do .
  • KennyP, boyscout862 and JRJ have said thanks
#3 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted November 22, 2013 - 06:23 PM
Busy little buggers, aren't they?
  • boyscout862 and JRJ have said thanks
#4 Texas Deere and Horse ONLINE
  • 14,812 Thanks
  • 15,501 posts
Posted November 22, 2013 - 06:27 PM
Wow Brian, that's quite a mess you have there. Hope you can repair the CB and get it up and running as you may need it shortly.
#5 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted November 22, 2013 - 07:42 PM
I had mice do something similar to my 2004 Silverado a couple of years ago . Seems that there was a small ventilation hole in the side of the fusebox under the hood and a mouse thought that be a good spot to build a nest .
I knew something was up when I was mowing the grass and I kept smelling a odor that smelled like wiring getting hot whenever I was near my truck .
Thank goodness my insurance covered the repairs . My local Chevrolet dealership had to put in a new fusebox and main wiring harness and I seen the bill that was $2500 . It only set me back the deductible which I think was $200 .
I also have problems with mice building nests inside the Kohler sheet metal of my cubs usually around this time of year .
I usually just put a couple of moth balls inside the engine compartment . Mice supposedly hate the smell of moth balls and I've been told dryer sheets also . So far it seems to work .
Edited by Jlaws, November 22, 2013 - 07:43 PM.
  • Alc, JDBrian, bgkid2966 and 1 other said thanks
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 22, 2013 - 08:17 PM
I'll have to check the other heat pump and make sure there hasn't been any unwelcome visitors. I wonder how long they were in there? We used that machine quite a bit this summer for AC and then didn't use it much for a couple of months until heating season started. I was into the HVAC supplier today to pick up a HRV fan motor and they said the boards for those machines are available and not too expensive, so if it doesn't work I'll pick up a new board for it. At least I can do the work myself and save on a service call.
  • bgkid2966, boyscout862 and JRJ have said thanks
#7 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted November 22, 2013 - 08:23 PM
The best solution for mice is a puddy tat.
That must be why the mod lounge stays mouse free.
Ben W.
#8 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Brian , its unbelievable how fast those mice can build a nest ...errr condo in your case  . My truck which is a daily driver had only sat for a couple of days when I developed issues .
Edited by Jlaws, November 22, 2013 - 08:24 PM.
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted November 22, 2013 - 09:11 PM
It sure looks like you have a mess on your hands Brian.  The moth balls do work, I use them in the shed where I keep one of my tractors.  I used to have to constently pull the tin's and clean out around the fly wheel.  Since I started using the moth balls I haven't had a problem.  The only thing is you have to put new moth balls in every few months, plus it is really hard getting the moths to let you have their balls,
  • JDBrian, bgkid2966 and boyscout862 have said thanks
#10 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted November 22, 2013 - 09:44 PM
Bill , my neighbor who is also named Bill , walked into my garage a few weeks ago and said he smelled moth balls .
I asked him , How do you get there little legs apart ?........LOL
  • shorty, HDWildBill, bgkid2966 and 2 others have said thanks
#11 HDWildBill OFFLINE
  • 8,975 Thanks
Posted November 22, 2013 - 11:23 PM
Very carefully.
#12 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 23, 2013 - 05:20 AM
LMAO!!!  :rolling:  :rolling:
  • bgkid2966 said thank you
#13 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted November 23, 2013 - 07:55 AM
If you know where they came in you can pack the opening with coarse steel wool. We have it packed around where all pipes come into our house.
Geno
  • JRJ said thank you
#14 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 23, 2013 - 05:03 PM
At the church we had an infestation last fall. We trapped them and sealed the holes with cement or epoxy. No mice this year ...so far anyway!
#15 TAHOE ONLINE
TAHOE
  • 7,976 Thanks
  • 5,676 posts
Posted November 23, 2013 - 07:19 PM
I am constantly fighting mouse in my barn, they like the bags of animals feed. Guess I got enough other spots, they stay out of the tractors/motors.
Those mini splits are cool. Our AC that goes to our church has started installing them in our old wing of church as we upgrade, more efficient to just heat/cool rooms that are being used.
